on 20-01-2023 07:37 PM
I have the ZTE801a and the Ethernet ports just stop working, I switch it around they work again then stop I switch them back and they work again and it repeats it again and again anyone else had this problem or does the router need flying lessons !
on 29-01-2023 01:45 PM
Three admitted router at fault so sent me a replacement
on 20-01-2023 10:58 PM
I have same router but do not as router only using modem so all wifi disabled just one port using for wan
Look like working ok Just three limiting speed this is bad "traffic management "
The router when I tested via wifi feels little week I mean for my need this wifi to week will be overloaded from my equipment
on 20-01-2023 11:04 PM
