3 weeks ago - last edited 3 weeks ago
Hi
I purchased Zyxel NR5103E its updated a few times on first switch on now with V1.00(ACBJ.0)b15, after a reset I set it up everything worked port forwards, I could setup ipv4 to get ddns was updated. After 1 day its gone I had to reset it and setup again, now half day later I can reach my server from internet side but on the same network from lan side not, I reseted again and its works fine again for a while I think, both side. Is it a known bug like the online firmware update option once availble once not or the https certificate and once they fix it or just buy a normal router which can fully functional as router and use this as a modem?
Thanks for the advises.
