on 07-12-2022 10:25 AM
My new router will not allow me to connect to the Admin portal via 192.168.1.254 which results in the message “This site can’t be reached. 192.168.1.254 refused to connect.”
I have tried via laptop, iPad and mobile phone. By directly entering the address into various browsers and via the Three app all with the same outcome. The app also won’t change the router name and passwords when attempted.
Spoke to a Three “technical advisor” who told me to call Sercomm, but could only give me a Bulgarian contact number…
on 25-02-2023 01:28 PM
I'm having the same issue with the Sercomm LTE2122GR hub - seems to be no way to connect to it as admin. It refuses connection before you get a chance to enter username/password. I think Three locked this router down so tight it's unusable.
on 15-12-2022 08:03 PM
and yes I can also connect to the internet fine.
on 21-02-2023 09:41 AM
Anyone had any further success with this issue?
on 09-12-2022 04:36 PM
Try this. In the search bar on your pc type cmd and then open the command prompt window. Then type ipconfig and scroll down the list until you find default gateway and try that ip address. It works for me and there is no risk of screwing anything up. Just click the close box on the cmd window when finished.
on 09-12-2022 04:37 PM
Thanks @sc1999 I forgot to put the instructions in on how to check, much appreciated.
on 15-12-2022 08:02 PM
Default gateway comes up as the same ip.
09-12-2022 04:13 PM - edited 09-12-2022 04:13 PM
Hello @Manse_man ,
I have not used this router before so I can only give a generic troubleshooting opinion. Can you connect to the internet fine? Also have you changed the subnet on the router? Possibly it could be a different subnet (so for instance like 192.168.3.1 or etc).
on 09-12-2022 11:55 AM
Yes, tried a few different ip, they all result in "this site cant be reached."
Its a shame no-one from Three is willing to help.
on 09-12-2022 12:28 PM
Message them direct. Try About JonathanB - Three Community
