12-07-2022 03:16 PM - edited 12-07-2022 03:36 PM
Instead of deleting my post, fix your rubbish network. You have left a whole market town with no service.
on 12-07-2022 04:02 PM
Hi Sam,
We haven't deleted any of your posts, but if multiple conversations are created about the same subject they do get merged. The post you're referring to is now showing as a comment on Mast unusable since "Upgrade" it hasn't been removed.
I'm sorry to hear that you're still encountering issues with the local coverage, we've sent a PM to you with the best advice on how to proceed.
on 14-07-2022 09:41 PM
I saw activity down at my mast so I think it might be getting fixed. Thanks.
Hi Sam,
