on 08-05-2025 05:48 PM
Hi
Is there a limit to how much of my data allowance I can use as a hotspot? I'm having issues with my current broadband provider and I don't want to sign any new contracts for the time being. So can I use my phone as de-facto WiFi hub?
on 08-05-2025 07:48 PM
Yes you can. Tethering is up to whatever your mobile allowance is. You’ll be fine.
