on 12-05-2023 09:17 AM
Hello,
I use ZTE 5G Home broadband modem. When I try to connect my company VPN it keeps disconnecting after a while. Company use `pulse secure` for vpn. I made some research this is not about with modem position (I have good signal quality) or something simple like reset your modem etc. It is a big issue for me and also there are so many user like me. I ask for three's professional support for this problem because I can not work.
Thank you.
on 21-08-2024 02:06 PM
I have the same issue
on 23-08-2023 08:30 AM
Hi All...
New Three 5g customer here and was finding everythign fantastic - great connection good speeds etc - all until i started to try and VPN into to work.
We also use Pulse Secure as our VPN provider and i have the same issue of being repeatedly disconnected.
Unfortunately if this can't be fixed I have no option but to cancel the new subscription - which i really don't want to do!
Please - is there a fix available?!
on 05-07-2023 02:40 PM
Hi Everyone,
I've noticed a few discussions cropping up about issues using VPNs over Three Broadband connections recently. I'm sending everyone that has mentioned this so far a PM so that we can get you in touch with some colleagues that will verify your accounts, and gather more info to help us investigate.
If you're experiencing this issue but haven't posted yet, please add a reply so that I can get in touch, the more examples I can gather, the easier it should be for our support teams to pinpoint what's causing the issues.
on 19-03-2025 03:43 PM
I too am having this problem trying to connect nhs vpn to my three WiFi router 4g
on 20-03-2025 12:29 PM
Hey @Alex7
Welcome to the Three Community page.
Sorry to hear that you're having this trouble with connecting to your VPN.
Here is a link to someone who had a similar issue and found a way to resolve this: Solved: FYI : IPv6 Prevented VPN Connection - Three Community - 14851
Please give this a try and let us know how you get on.
Jade
on 18-09-2024 02:32 AM
Hi Jonathan, I am having this issue. I am new to three 5g hub and after having several sessions with IT team at my work place, we have found that the router is blocking my work VPN connection. I need some help please
19-09-2024 11:42 AM - edited 19-09-2024 12:08 PM
Hi there @rajafaisaltariq
I had the same issue when I changed over to Three 5G home Broadband this year. Following is the solution I used and it worked for me as well as many others:
https://community.three.co.uk/t5/Broadband/FYI-IPv6-Prevented-VPN-Connection/m-p/14851#U14851
Here you'll find two responses, one clarifies the issue from a techincal point of view, the other user have described the steps to access your router to change the APN to manual, and then configuring your PDP for IPv4 only. Hopefully this resolves the issue, good luck.
on 21-08-2024 02:09 PM
I'm affected by this issue too!
on 11-06-2024 08:52 AM
Hello I can't access my work von though my router can you help?
