5g not working with my devices
CD22
I have just upgraded to 5g and a new router, hopeful everything would be better but a lot of my things now won’t work, ring doorbell and cameras and also limited channels on my tv, definitely can’t get Netflix or Prime, can anyone help me please 🙂
10 REPLIES 10
Dazzar
Established
@CD22  Stupid question but have you changed all your equipment to the new address the new hub is sending out if not of course they will not work, also do t forget ring works on 2.4 only on most of their items so make sure it’s turned on
Hi @CD22,
I'm sorry to hear that you've been running into issues with these devices since the upgrade. There was an issue with a recent software update that may be causing this, but if that's the case we should be able to fix it.
I'll send you a private message to direct you to some colleagues that can get this raised with the relevant technical team.
DavidMack
Hi Johnathan - As of 19 July 2023 what I presume is a software update has knocked out all my 2.4Ghz devices such as the cctv cameras (of different makes). I wonder if this will be fixed?
Hi @DavidMack,
This thread is quite old and referring to a different issue, but you may find a solution these threads: FYI : IPv6 Prevented VPN Connection or New B14 Firmware For NR5103 has broken UPnP / Gaming!
Jax
As you've now created a completely new network with a new ISP, then some of your equipment will require re-configuring to the new network, which can be so frustratingly annoying, but you'll have to do it regardless. Best of luck.
Anvil_Iron
Sounds like you are having a Wi-Fi/LAN problem rather than a mobile connection problem. Is your mobile connection working normally?
Normally with a new router, Wi-Fi needs to be configured to the SSID and password your devices were using before.
Geluk
Maestro
5G widely oversold; suggest you connect at 4G which presumably works.
CD22
I spoke to three and received it yesterday and plugged in only to find out then that nothing much will work, so I wanted to make sure it’s not me doing something wrong before I send it back and go elsewhere.
sc1999
Local celebrity
I cannot help but the first question people will ask is what router have you got?
