on 25-07-2024 11:38 AM
After lots of fiddling I've finally figured out how to get the Zyxel working with IP Passthrough. In other words, the Zyxel is my modem, and I'm using it with my own WiFi router downstream. Here are the steps I followed:
1. Go to Network Settings -> Broadband -> Broadband tab and edit Cellular WAN 1. Switch off NAT.
2. Go to Network Settings -> Broadband -> Cellular APN tab and edit the first one in the list. Turn APN Manual Mode on and then change the APN to three.co.uk and switch PDP Type to IPv4.
3. Go to the hamburger menu and Restart the router. Don't pull the plug, just restart it from the UI.
4. Go to Network Settings -> Broadband -> Cellular IP Passthrough tab and switch it on. At this point if you go back to the Home screen, you will most likely still see a local IP address in the Cellular Info, probably 192.168.1.2. It will probably also report that it has lost connection to the internet.
5. Again, go to the hamburger menu and Restart the router.
6. Once the router has restarted, look again at the Cellular Info and it should show your WAN IP address, something like 10.123.xx.xxx or similar. The Status should also say it is Up.
7. Plug in your own Wifi router to LAN 1, NOT LAN 2/WAN!!! Give it a minute. Your router should eventually get assigned the WAN IP and you're good to go.
Notes
- The internet icon on the top of the Zyxel should be blue in IP Passthrough mode. Don't assume it isn't working because it hasn't gone green yet.
- The LAN2/WAN descriptor is extremely confusing. This is if you want to provide an internet connection to the Zyxel via Ethernet cable on LAN 2. There is an option to switch this on in the broadband settings. You don't need it.
- You need to regularly restart the Zyxel for things to work properly. I noticed that some things would 'half-work' if you just apply the settings but don't restart. If something isn't working as expected, restart the Zyxel from the UI (don't pull the plug).
- I did all of this while connected to my downstream router's wifi. Even though it might not have an internet connection at various points, you should still be able to access the Zyxel admin panel if your router is connected via Ethernet on LAN 1.
- Don't mess around with DHCP settings. Leave them as they are.
- I've not tried turning off the Zyxel WLAN (Wifi networks) yet but I don't see why it would cause any issues.
Here are some screenshots of my settings:
on 20-08-2024 04:06 PM
Nice one. I found out the same, particularly the LAN1 bit - was driving me mad!
How to you connect to your 5G router for admin? I've a cable from my main router to the 5G one, WAN to LAN1, and its fine. However, to access it for admin, I have to know my external IP, then either add 1 or subtract 1, from the last digit of the address, and then I can access it from my LAN (my 192.168 network) - most odd, but it works.
i.e. if Three give the 5G router 96.23.23.200 (made up)... then to access the Admin of the 5G router on my internal network I have to enter, usually, 96.23.23.201, but, sometimes 96.23.23.199 (never both). Most odd!
So if I lose internet and need to access the 5G box for a reboot, I need to find its IP in my internal router settings, then use that (+ or - 1 !!)
on 19-09-2024 04:04 PM
I've been accessing my 5G router on 192.168.1.1 and my Wifi Router at the IP it was assigned by the 5G router. The difference is probably because of our different NAT settings. I'm going to try your setup as I have been having small issues with connections for various things.
on 19-09-2024 04:14 PM
Just re-enabled NAT on Cellular WAN 1 and rebooted the 5G router. I'm still able to access it on 192.168.1.1.
To get to my Wifi Router, I just use the IP address in the Cellular Info section of the 5G router's home screen.
on 25-07-2024 11:58 AM
Hi @jamesmarkcook,
Thanks for taking the time to create such a detailed step by step guide, and for including screenshots too. Hopefully this will be really helpful for other community members!
