Huawei B535-232 Certificate has Expired
cancunia
Apologies for the double post, I put the original in 'Data' by mistake, it looks like it should have been in Broadband..
The certificate on the management web pages for the B535-232 has expired which means it needs a security breach in order to access the management pages. The router is on the latest firmware, but the certificate expired in November:
Software version 11.0.1.2(H200SP5C21)
Web UI version WEBUI 11.0.1.1(W2SP4C21)
Configuration file version B535-232-CUST 10.0.1.2(C21)
NET::ERR_CERT_DATE_INVALID
Subject: www.hirouter.net
Issuer: Actalis Organization Validated Server CA G3
Expires on: Nov 16, 2022
Current date: Dec 27, 2022
51 REPLIES 51
steve_pr
Thanks for this. Enabled me to log in to the router admin pages but still doesn't seem to like serving up DHCP addresses!
cancunia
Thanks for following this up. As you mentioned above, it is possible to bypass the security warning, but an update to the certificate would be the correct solution longer term.
