EDIflyer
573 REPLIES 573
AkiTaiyo
Interestingly, this is redirecting even though my setting is set to allow adult content..
AkiTaiyo
Changed to three.co.uk APN and it works again??..
toaster
I'm still seeing a lot of issues. I'm mostly struck by the range of sites affected (amazon, wikipedia, IMDB, steam, AWS S3, facebook, github) and how variable things are for individual sites.
e.g.:
  • Failed connections to Wordpress,org have gone from not really appearing on the 19th/20th to failing nearly 50% of the time last night!
  • Connections to my test server fail anywhere from 0%-2.6% of the time
Out of the 114 test sites, sometimes only 8 sites (~7%) are affected during a test (~7 hours) - othertimes up to 20 sites (~18%) are affected.
21 May (AM)
  • 'royalmail.com': 5.2%,
  • 'github.com': 0.2%,
  • 'ghcr.io': 0.4%,
  • 'facebook.com': 0.2%,
  • 'play.google.com': 0.2%,
  • 'amazon.com': 0.2%,
  • 'vk.com': 8.8%,
  • 'ec.europa.eu': 0.4%,
  • 's3.amazonaws.com': 0.4%,
  • 'microsoft.com': 1.4%,
  • 'aws.amazon.com': 0.2%,
  • 's.w.org': 0.2%,
  • 'nytimes.com': 0.4%,
  • 'ted.com': 0.2%
May 21 (PM)
  • 'royalmail.com': 5.0%,
  • 'github.com': 0.4%,
  • '<My AWS https server>': 0.4%,
  • 'duckduckgo.com': 0.4%,
  • 'wordpress.org': 0.6%,
  • 'amazon.com': 0.4%,
  • 'vk.com': 9.6%,
  • 's3.amazonaws.com': 1.0%,
  • 'microsoft.com': 0.4%,
  • 'aws.amazon.com': 0.4%,
  • theguardian.com': 0.2%,
  • 'discord.gg': 0.2%
May 22 day (AM)
  • 'royalmail.com': 4.2%,
  • 'instagram.com': 0.2%,
  • 'linkedin.com': 0.2%,
  • 'vk.com': 1.4%,
  • 'reddit.com': 0.2%,
  • 'paypal.com': 0.2%,
  • 'support.apple.com': 0.4%,
  • 'ted.com': 0.2%
May 22 (PM - afternoon)
  • 'royalmail.com': 1.2%,
  • '<My AWS https server>': 0.6%,
  • 'gmpg.org': 0.4%,
  • 'wordpress.org': 27.0%,
  • 'amazon.com': 1.4%,
  • 'vk.com': 4.8%,
  • 's3.amazonaws.com': 0.6%,
  • 'microsoft.com': 2.2%,
  • 's.w.org': 33.4%,
  • 'mozilla.org': 0.4%,
  • 'imdb.com': 1.4%,
  • 'web.archive.org': 0.2%,
  • 'ted.com': 0.8
May 22 (PM -night)
  • '<My AWS https server>': 2.6%,
  • 'gmpg.org': 0.2%,
  • 'wordpress.org': 48.6%,
  • 'amazon.com': 3.4%,
  • 's3.amazonaws.com': 3.8%,
  • 'microsoft.com': 1.8%,
  • 's.w.org': 42.0%,
  • 'imdb.com': 2.8%,
  • 'web.archive.org': 0.4%,
  • 'ted.com': 2.0%,
  • 'oracle.com': 0.2%,
  • 'store.steampowered.com': 0.2%
Midnight54
Established
After installing linux to windows and trying @wgen s script, most sites are passing the test (only 1 I know of that is failing - however the issue is definitely still there as getting some pages still failing to load - it is fairly late however so maybe increases the success rate.  I also tried a debrid file download and still getting exact same issue (chrome loops forever downloading from start, reports Failed if use Firefox at end of file but hit retry several times and it eventually says complete (without redownloading the whole thing)
Will try to test more tomorrow evening
bytespider
No change here though issues do seem less frequent. Ironically the only issue I had today was the EOF while trying to get to ProtonVPN to set up a new virtual machine for testing
AkiTaiyo
This has now been running for 6+ hours, looks like the web site errors have gone away:
https://www.jdoqocy.com              Req: 2094         Fail: 0 SSL Err: 0
https://www.topcashback.co.uk        Req: 2094  Fail: 0 SSL Err: 0
https://retail.santander.co.uk       Req: 2094  Fail: 0 SSL Err: 0
https://github.com                   Req: 2094  Fail: 1 SSL Err: 0
https://raw.githubusercontent.com    Req: 2094  Fail: 1 SSL Err: 0
https://ghcr.io                      Req: 2094  Fail: 0 SSL Err: 0
https://www.skyscanner.net           Req: 2094  Fail: 0 SSL Err: 0
https://www.netomnia.com             Req: 2094  Fail: 0 SSL Err: 0
https://diy.com                      Req: 2094  Fail: 0 SSL Err: 0
https://duckduckgo.com               Req: 2094  Fail: 0 SSL Err: 0
https://inews.co.uk                  Req: 2094  Fail: 0 SSL Err: 0
https://news.sky.com                 Req: 2094  Fail: 0 SSL Err: 0
https://visualstudio.microsoft.com   Req: 2094  Fail: 0 SSL Err: 0
https://new.three.co.uk              Req: 2094  Fail: 0 SSL Err: 0
https://wordpress.org                Req: 2094  Fail: 0 SSL Err: 0
https://en.wikipedia.org             Req: 2094  Fail: 0 SSL Err: 0
https://commons.wikimedia.org        Req: 2094  Fail: 0 SSL Err: 0
https://vk.com                       Req: 2094  Fail: 0 SSL Err: 0
https://de.wikipedia.org             Req: 2094  Fail: 0 SSL Err: 0
https://itunes.apple.com             Req: 2094  Fail: 0 SSL Err: 0
https://youtube.com                  Req: 2094  Fail: 0 SSL Err: 0
https://facebook.com                 Req: 2094  Fail: 0 SSL Err: 0
https://instagram.com                Req: 2094  Fail: 0 SSL Err: 0
https://twitter.com                  Req: 2094  Fail: 0 SSL Err: 0
https://pinterest.com                Req: 2094  Fail: 0 SSL Err: 0
https://play.google.com              Req: 2094  Fail: 0 SSL Err: 0
https://reddit.com                   Req: 2094  Fail: 0 SSL Err: 0
https://amazon.com                   Req: 2094  Fail: 0 SSL Err: 0
https://microsoft.com                Req: 2094  Fail: 0 SSL Err: 0
https://imdb.com                     Req: 2094  Fail: 0 SSL Err: 0
https://linkedin.com                 Req: 2074  Fail: 0 SSL Err: 0
https://nytimes.com                  Req: 2094  Fail: 0 SSL Err: 0
The two fails where timeouts when I ran my system out of RAM.
Although I now have a new error where I've been unable to connect to a Google Colab instance all day, without using a VPN...
Midnight54
Established
Have a dummies guide on how to do this and I'll set it for my own where I have the issues? 🙂
Midnight54
Established
So I just had a slightly different test/problem likely from the same reason.  A game I play, DCS World, had its first big update out today since I started having the problems, so went to run the DCS Updater, which is its own dedicated exe.  This errored multiple times with the following message
00000.000 === Log opened UTC 2024-05-22 19:47:47
00000.035 INFO : DCS_Updater/2.16.3.18 (Windows NT 10.0.19045; Win64; en-GB)
00000.035 INFO : src-id: <removed-justincaseitssensitive>, lib-id: <removed-justincaseitssensitive>
00000.035 INFO : cmdline: "C:\Program Files\Eagle Dynamics\DCS World OpenBeta\bin\DCS_updater.exe" update
00000.069 STATUS: Initializing...
00000.070 INFO : basedir: C:\Program Files\Eagle Dynamics\DCS World OpenBeta
00000.070 INFO : variant: openbeta
00000.070 INFO : DCS/2.9.4.53990 (x86_64; EN; WORLD,A-10C_2,SUPERCARRIER,HEATBLUR_F-14,FA-18C,FC3,KA-50,A-10C,MARIANAISLANDS_terrain,PERSIANGULF_terrain,SYRIA_terrain,AH-64D,UH-1H,AJS37,RAZBAM_AV8BNA,RAZBAM_M-2000C,BALTICDRAGON_FA18C_RAVEN_ONE_campaign,NEVADA_terrain,F-16C,THECHANNEL_terrain,WWII-ARMOUR,SPITFIRE-MKIX,MOSQUITO-FBMKVI,P47D30,BALTICDRAGON_A10C_IRON_FLAG_PART1_campaign,KA-50_3,MIG-21BIS,MI-24P,P-51D,MIG-15BIS,F-86F,F-5E,BF-109K4,FW-190D9,FW-190A8,CAUCASUS_terrain,NORMANDY_terrain,MI-8MTV2,POLYCHOPSIM_SA342,RAZBAM_F-15E)
00000.070 INFO : branch: openbeta
00000.073 STATUS: Checking for updates...
00000.450 INFO : Got reply from www.digitalcombatsimulator.com
00000.500 ERROR: Conection to server 'www.digitalcombatsimulator.com' failed: SSL connect error
00000.500 ERROR: www.digitalcombatsimulator.com replied HTTP -1
00000.501 STATUS: SSL connect error
00002.089 === Log closed.
The last few lines being the key thing - The only way I got the updater to work in the end was having to go to the games webpage to get the webpage to load first in the browser, before the updater would then finally run, where it it fine and currently downloading at around 600-700mbps
Midnight54
Established
To add to this, the way this game updates, when you buy a new module (which I did as was released today), the only way to then download the newly purchased module, is to launch the game, then select the new module (airplane) from the list, which then closes the game and relaunches the updater.....this then fails with the same error....multiple times, because of Three's stupid issues!!!
Luckily I managed to do a workaround to make it work but its far from ideal for people.  I had to load the game, go to the update section in order to select the newly bought module.  Before I pressed to download it, I then had to tab out, load up a web browser, fire up the games website to make sure it was loaded, quickly tab back to the game then tell it to download!!!
Three........please respond and fix this stuff.......For the guys affected please give updates, have you made any changes, or rolled back any changes made in some areas?  A game aside, its ridiculous that I cant even do normal banking or online shopping without pages failing!!!!
AkiTaiyo
I had an outage on Three this morning at about 6AM.
Been running my test app for the past two hours (32 sites, 10s request intervals), 0 failures so far..  Has something changed?
Type a product name
