EDIflyer
626 REPLIES 626
Nameless
Established
Thank you for sharing the information - That is quite the significant difference! I was not expecting the VPN to reduce your speeds by that much
I can only imagine what WARP+ would be like in comparison but standard WARP is good enough for my needs at this time
Midnight54
Established
Dont partically want to be slowing my speeds by using effectively a VPN,worsening pc performance, increasing my power consumption by using additional apps, on top of vpns add risk to me losing certain accounts if seen in use in more than 1 location at the same time, which would happen risk with my nvidia Shield and PC usage in that case
Does this suggest that putting the modem into bridge mode instead could work and adding a seperate router with DNS being set on that?  as I have an AX3000T that yet to get around to plugging in
Nameless
Established
Speeds will not be significantly slowed below ~200Mbps but that may also depend upon your CPU more than anything:
  • My main testing computer uses an AMD Ryzen 7 5700G that is software optimised for power savings rather than running at stock and had no issues when reaching ~400+Mbps despite significant multitasking that had all cores running at ~100%
     - Clock speed range is 0.4GHz-4.673GHz, speeding up by 0.2GHz every 0.2 seconds when CPU usage is >30%
     - It is undervolted slightly but that is the motherboard maximum
  • On that same computer, WARP did touch above single core saturation (6.25%) but not dual core saturation (12.50%) in its usual optimised mode however I am unable to test for speeds higher than 1000Mbps which is where WARP's overhead would be more significant
     - These percentages vary dependent on the CPU clock speed:
        - Lower percent reported at higher CPU clock speeds at the same download/upload speeds
     - The protocol overhead seems to be around 10%
Unless your usual internet needs require minimum speeds far beyond 150Mbps then you should be fine although any random large download, such as a multi-gigabyte game download, will take longer on your WARP enabled devices... But ideally we should not have any speed restrictions that are not caused by hardware limits
Overall computer performance wise, yes it is yet another program running but it can be negligible compared to other applications, most notably your web browser of choice, and background running tasks in some individual application cases (Manually adjusting many Windows background services can work really well but changing operating systems was still a better for my uses)
In regards to power consumption, if you have a dedicated GPU then that alone is likely to use far more energy than when running WARP but more processing does require more power nonetheless and is always a valid concern - It is also the reason for my main testing computer being software optimised for power savings
Unfortunately I do not use other VPNs at this time, traditional or WARP-like equivalents, and can not help there although using WARP still uses a regional IP address that should be a close match for your current region - This did result in the ISP being mentioned as Cloudflare when testing
Multiple routers may be less problematic on maximum internet speeds but would probably require more power than running WARP - If it works then finding an extremely low-powered router that does the job would be really useful
Midnight54
Established
My speeds are typically 600-950mbps so much more likely to affect me, but the IP risk of vpn is a big no no.  Its not about using a regional account.  Using the account in any 2 IP addresses at the same time as an immediate ban, and with 2 devices often using it at same time, something like WARP far too risky
bytespider
600-950 nice, I only get 300-500 and the tower is only 1/4mile away
MP
Yep, a lot of sites out there don't like VPNs and can result in account bans.
It is not a solution to use a VPN. Three need to fix this issue once and for all.
I am not looking at renewing my multiple contracts as it stands with them.
Midnight54
Established
Similarly, my contract I think is due within a couple of months, but I'm sick to death of this every time trying to update game
AkiTaiyo
After about a month of being absolutely fine.. the EOF errors have returned today after another short outage.
I spoke to a customer support rep a while back before the problem stopped, they initially told me that I'd need to pay off the remaining contract, but I said did that still apply when Three can't deliver a service I'm paying for.  After that they said they could cancel without charge if I returned the router.
I've been trailing EE at the same time whilst this has been happening, turns out they are also on the same mast so still get good reception and speed.   Their service has worked perfectly but a little more expensive to make the switch permanent (I've been trialing a PAYG sim).
I didn't make the switch in the end since the errors stopped happening for me, but now they are back I think I'll look at doing it again.
fashric
The complete non-response to this issue has convinced me that when my contract is up, I definitely won't be renewing.
bytespider
I'm going to cancel mine too. I've already suggested to several friends and family members not to go with Three. I'd like to hear some other options from others that are considering cancelling or have cancelled and moved to another provider.
