on 22-10-2023 03:21 PM
on 23-05-2024 07:41 PM
Changed to three.co.uk APN and it works again??..
23-05-2024 09:45 AM - edited 23-05-2024 09:46 AM
I'm still seeing a lot of issues. I'm mostly struck by the range of sites affected (amazon, wikipedia, IMDB, steam, AWS S3, facebook, github) and how variable things are for individual sites.
e.g.:
Out of the 114 test sites, sometimes only 8 sites (~7%) are affected during a test (~7 hours) - othertimes up to 20 sites (~18%) are affected.
21 May (AM)
May 21 (PM)
May 22 day (AM)
May 22 (PM - afternoon)
May 22 (PM -night)
22-05-2024 11:52 PM - edited 22-05-2024 11:52 PM
After installing linux to windows and trying @wgen s script, most sites are passing the test (only 1 I know of that is failing - however the issue is definitely still there as getting some pages still failing to load - it is fairly late however so maybe increases the success rate. I also tried a debrid file download and still getting exact same issue (chrome loops forever downloading from start, reports Failed if use Firefox at end of file but hit retry several times and it eventually says complete (without redownloading the whole thing)
Will try to test more tomorrow evening
on 22-05-2024 09:14 PM
No change here though issues do seem less frequent. Ironically the only issue I had today was the EOF while trying to get to ProtonVPN to set up a new virtual machine for testing
on 22-05-2024 08:57 PM
This has now been running for 6+ hours, looks like the web site errors have gone away:
https://www.jdoqocy.com Req: 2094 Fail: 0 SSL Err: 0
https://www.topcashback.co.uk Req: 2094 Fail: 0 SSL Err: 0
https://retail.santander.co.uk Req: 2094 Fail: 0 SSL Err: 0
https://github.com Req: 2094 Fail: 1 SSL Err: 0
https://raw.githubusercontent.com Req: 2094 Fail: 1 SSL Err: 0
https://ghcr.io Req: 2094 Fail: 0 SSL Err: 0
https://www.skyscanner.net Req: 2094 Fail: 0 SSL Err: 0
https://www.netomnia.com Req: 2094 Fail: 0 SSL Err: 0
https://diy.com Req: 2094 Fail: 0 SSL Err: 0
https://duckduckgo.com Req: 2094 Fail: 0 SSL Err: 0
https://inews.co.uk Req: 2094 Fail: 0 SSL Err: 0
https://news.sky.com Req: 2094 Fail: 0 SSL Err: 0
https://visualstudio.microsoft.com Req: 2094 Fail: 0 SSL Err: 0
https://new.three.co.uk Req: 2094 Fail: 0 SSL Err: 0
https://wordpress.org Req: 2094 Fail: 0 SSL Err: 0
https://en.wikipedia.org Req: 2094 Fail: 0 SSL Err: 0
https://commons.wikimedia.org Req: 2094 Fail: 0 SSL Err: 0
https://vk.com Req: 2094 Fail: 0 SSL Err: 0
https://de.wikipedia.org Req: 2094 Fail: 0 SSL Err: 0
https://itunes.apple.com Req: 2094 Fail: 0 SSL Err: 0
https://youtube.com Req: 2094 Fail: 0 SSL Err: 0
https://facebook.com Req: 2094 Fail: 0 SSL Err: 0
https://instagram.com Req: 2094 Fail: 0 SSL Err: 0
https://twitter.com Req: 2094 Fail: 0 SSL Err: 0
https://pinterest.com Req: 2094 Fail: 0 SSL Err: 0
https://play.google.com Req: 2094 Fail: 0 SSL Err: 0
https://reddit.com Req: 2094 Fail: 0 SSL Err: 0
https://amazon.com Req: 2094 Fail: 0 SSL Err: 0
https://microsoft.com Req: 2094 Fail: 0 SSL Err: 0
https://imdb.com Req: 2094 Fail: 0 SSL Err: 0
https://linkedin.com Req: 2074 Fail: 0 SSL Err: 0
https://nytimes.com Req: 2094 Fail: 0 SSL Err: 0
The two fails where timeouts when I ran my system out of RAM.
Although I now have a new error where I've been unable to connect to a Google Colab instance all day, without using a VPN...
on 22-05-2024 09:00 PM
Have a dummies guide on how to do this and I'll set it for my own where I have the issues? 🙂
22-05-2024 08:53 PM - edited 22-05-2024 08:59 PM
So I just had a slightly different test/problem likely from the same reason. A game I play, DCS World, had its first big update out today since I started having the problems, so went to run the DCS Updater, which is its own dedicated exe. This errored multiple times with the following message
00000.000 === Log opened UTC 2024-05-22 19:47:47
00000.035 INFO : DCS_Updater/2.16.3.18 (Windows NT 10.0.19045; Win64; en-GB)
00000.035 INFO : src-id: <removed-justincaseitssensitive>, lib-id: <removed-justincaseitssensitive>
00000.035 INFO : cmdline: "C:\Program Files\Eagle Dynamics\DCS World OpenBeta\bin\DCS_updater.exe" update
00000.069 STATUS: Initializing...
00000.070 INFO : basedir: C:\Program Files\Eagle Dynamics\DCS World OpenBeta
00000.070 INFO : variant: openbeta
00000.070 INFO : DCS/2.9.4.53990 (x86_64; EN; WORLD,A-10C_2,SUPERCARRIER,HEATBLUR_F-14,FA-18C,FC3,KA-50,A-10C,MARIANAISLANDS_terrain,PERSIANGULF_terrain,SYRIA_terrain,AH-64D,UH-1H,AJS37,RAZBAM_AV8BNA,RAZBAM_M-2000C,BALTICDRAGON_FA18C_RAVEN_ONE_campaign,NEVADA_terrain,F-16C,THECHANNEL_terrain,WWII-ARMOUR,SPITFIRE-MKIX,MOSQUITO-FBMKVI,P47D30,BALTICDRAGON_A10C_IRON_FLAG_PART1_campaign,KA-50_3,MIG-21BIS,MI-24P,P-51D,MIG-15BIS,F-86F,F-5E,BF-109K4,FW-190D9,FW-190A8,CAUCASUS_terrain,NORMANDY_terrain,MI-8MTV2,POLYCHOPSIM_SA342,RAZBAM_F-15E)
00000.070 INFO : branch: openbeta
00000.073 STATUS: Checking for updates...
00000.450 INFO : Got reply from www.digitalcombatsimulator.com
00000.500 ERROR: Conection to server 'www.digitalcombatsimulator.com' failed: SSL connect error
00000.500 ERROR: www.digitalcombatsimulator.com replied HTTP -1
00000.501 STATUS: SSL connect error
00002.089 === Log closed.
The last few lines being the key thing - The only way I got the updater to work in the end was having to go to the games webpage to get the webpage to load first in the browser, before the updater would then finally run, where it it fine and currently downloading at around 600-700mbps
on 22-05-2024 09:09 PM
To add to this, the way this game updates, when you buy a new module (which I did as was released today), the only way to then download the newly purchased module, is to launch the game, then select the new module (airplane) from the list, which then closes the game and relaunches the updater.....this then fails with the same error....multiple times, because of Three's stupid issues!!!
Luckily I managed to do a workaround to make it work but its far from ideal for people. I had to load the game, go to the update section in order to select the newly bought module. Before I pressed to download it, I then had to tab out, load up a web browser, fire up the games website to make sure it was loaded, quickly tab back to the game then tell it to download!!!
Three........please respond and fix this stuff.......For the guys affected please give updates, have you made any changes, or rolled back any changes made in some areas? A game aside, its ridiculous that I cant even do normal banking or online shopping without pages failing!!!!
on 22-05-2024 09:20 AM
I had an outage on Three this morning at about 6AM.
Been running my test app for the past two hours (32 sites, 10s request intervals), 0 failures so far.. Has something changed?
on 22-05-2024 10:08 AM
Very interesting - that fits a bit with the experience I had last week of an outage and then the system working afterwards without errors!
