EDIflyer
626 REPLIES 626
l0hn
I've setup a permanent VPN connection on my router as a workaround and no longer get SSL errors.
This is obviously because the VPN circumvents Three's proxy which is interferring with TLS handshakes, assumably sniffing the plain text domain from the handshake for a firewall.
@JonathanB : What gives here? If you guys want to monitor TLS streams at least do it in a way that isn't as noticeable and doesn't cause such an impact to customers.
l0hn
Well that's just brilliant, I've moved to an area where 5G is the only option until FTTP is rolled out and this initially seemed great as I can achieve ~1gbps.. but it's completely pointless if Three's internal proxy constantly drops packets during TLS handshakes.
I expect a permanent VPN connection on my router will workaround this but this shouldn't be necessary.
@JonathanB: Can you ask someone there if it's possible for specific clients to bypass the proxy? At least keep some of us happy until you can fix this?
Also what's the reason for doing this? Assumably you're using the TLS handshake to sniff the plain text domain for a firewall. The least you could do if you're going to monitor / persist TLS streams is do it well enough that it goes un-noticed.
MP
Does anyone have an Apple Watch and the Weather app does not always show information (tried all the obvious things to make it work and reinstalling the app), I would assume all traffic is SSL/TLS so I was wondering if it is related to this in some way.
Midnight54
Established
Seems especially bad for me today.  especially duckduckgo, asda.com, groceries.asda.com, and even amazon (tho less often).  Also noticed that using a site such as hotukdeals, the referral links they use that take through to the actual amazon page are very frequently failing so needing to refresh pages multiple times, "An error occurred during a connection to hotukdeals.digidip.net. PR_END_OF_FILE_ERROR"
Midnight54
Established
Like @EDIflyer my net also went down last night for approx 10mins, around 1am ish.  Only just had time to test it, hoping it was maybe resolved,but nope same issue here, sites like duckduckgo fairly frequently failing, debrid files failing to complete the download at the very end every time etc
EDIflyer
Oh damn, sorry to hear that - interesting you had an outage though too.
wgen
Sure, I will be down to participate. Issues are still prevalent on my connection.
Hi everyone,
@EDIflyer mentioned they haven't been seeing the same error recently, but I don't want to write this off as resolved, particularly when others have mentioned this issue coming and going in the past.
We'd like to do some live tracing against affected connections. Is anyone interested in participating in this?
thelostlambda
Hi Jonathan!
I've been away from the UK since December or so, but since coming back last week I've been suffering this problem quite badly... I'd love to participate / provide helpful information to get this issue resolved ASAP!
Thanks a ton!
bytespider
Id be happy to help.
