on 22-10-2023 03:21 PM
on 11-09-2025 01:22 PM
For me it's always reliably Docker. Over 300 times I had a script retry pulling an images from lscr.io before eventually it succeeded.
delay=3; count=0; while ! docker compose pull; do count=$((count + 1)); echo "Retry #$count failed, retrying in $delay seconds... (Ctrl+C to abort)"; sleep $delay; done
on 11-09-2025 01:27 PM
Yeah, Docker can become pretty much unusable without having to shell out for a VPN. Much like git
on 11-09-2025 01:06 PM
Day: 690
Status: Service still broken
Three update: Non-forthcoming
on 10-09-2025 10:01 AM
Found a website that fails 50% of the time for me when using the test script, but no problems when turning on a VPN
https://hotukdeals.digidip.net
Results after running the command 10 times:
Successes: 56
Failures: 44
Hope that helps someone more technical than me work out what is going on
on 08-09-2025 08:20 AM
Still no updates, the issue also discussed here with traces and proof of issues
https://www.ispreview.co.uk/talk/threads/three-tampering-with-ssl-traffic-why.43292/
on 27-08-2025 01:20 PM
@PeteG we were told this is being looked into but still months go by and no updates?
on 05-08-2025 11:40 AM
Day: 654
on 03-08-2025 10:17 PM
Did a quick test yesterday on the unusual band combination of B3 with N78 appearing twice
Testing speeds were averaging closer to 800Mbps rather than 600Mbps despite the time of day
More importantly, there have been no changes
Cloudflare's WARP continues to work for myself despite the download speed reductions due to its overhead
I wonder if such mitigations will still be needed under Vodafone's systems although iD Mobile seems to be absent in the announcements unlike the other MVNOs
on 04-08-2025 05:41 PM
I left Three during my cooling off period and jumped to talkmobile, a Vodafone NVMO (I think it might even be owned by Vodafone). It certainly does not have the TLS problems that Three has. I do get connections dropped from time to time when streaming internet radio, but I had a bit of that on my old landline too, although talkmobile is definitely worse at it. I don't notice issues with anything else.
I think it's a good service. Cheaper than Three and a one month rolling contract so easy to leave if it becomes rubbish. The only downside is there's no router - it's a mobile phone contract that allows tethering. I'm technically minded, so rolled my own router on a Raspberry Pi and plugged an old mobile phone into a USB slot. Not as fast as Three, but faster than my landline ever was so I'm happy.
on 01-08-2025 01:55 PM
Been trying to do some remote working today from home. Had so many issues trying to connect to the vpn/microsoft authentication/remote app. This is actually horrible
