on 22-10-2023 03:21 PM
01-08-2025 10:37 PM - edited 01-08-2025 10:37 PM
Yep. It is thoroughly broken for a lot of use cases. Basically terminates the connection early. Welcome to the black hole that is this thread. Don't expect a resolution, as there has not been one for nearly 2 years now, but at least you aren't suffering alone.
Not that this is much consolation.
on 31-07-2025 12:10 AM
Day: 649
Status: Service still broken
Three update: Non-forthcoming
on 01-08-2025 05:01 PM
But they have "Improved the network" according to the latest email. 😅
on 22-07-2025 02:36 AM
Hi Three! Thanks for the updates, it's great to know that you are really working hammer and tongs to fix this issue. I really value how much you prioritise keeping your paying customers updated. This is hugely appreciated.
Just checking in to let you know that your service is still broken, but don't worry about it. Just in your own time, y'know.
x
on 24-07-2025 04:46 PM
I wonder how well Vodafone is equipped to take on the complaints that Three has been getting? Maybe that side of the merged company will actually do something
No changes to report from my tests
06-07-2025 12:43 AM - edited 06-07-2025 12:44 AM
Time passes, everything changes. Everything except Three's ability to fix a longstanding problem, or communicate **anything** to their customers at all.
You really do love treating your customers like the absolute mugs that we clearly are.
I got a promotional email the other day asking me to refer my friends to Three. Made me laugh, but then not altogether surprising, sadly for you, I don't tend to treat my friends the way you treat your customers, so I am actively doing the opposite.
07-07-2025 09:29 AM - edited 07-07-2025 09:35 AM
I don't know if there's been a change, but I've been away from home for 10 days, got back and work day today, so switch to 5G while everyone is out for the day, did a few runs of the test script using the script posted here some time back (PPBJ2M4S.bat I have it saved as), and I've had multiple runs this morning with 0 failures! Actually, now 10 runs, each of 100 connections, so 1000 connections with no failures.. I shall keep the VPN off for the day and see what occurs.. Make that 11 runs now..
99 success
100 success
Results after running the command 100 times:
Successes: 100
Failures: 0
on 07-07-2025 06:29 PM
Things seemed more stable than usual here with the rarely seen band combination of B20 and B3 with N78
The error did eventually appear after ~1 hour of random website testing
In other news, switching APN details from within the NR5103EV2 router does not seem to work properly unless the router is restarted - I did observe some unusual changes in overall broadband speeds such as increased average download speed from ~600Mbps to ~800Mbps however this is unlikely to persist as temporary speed increases often occur when the router is restarted and it does disconnect for a few seconds
I will need to try the Vodafone APNs properly another day
07-07-2025 02:18 PM - edited 07-07-2025 02:18 PM
Oh well, that didn't last long, ~5 hours later and it's now at a 3% failure rate 😞
Same mast, same channels, very odd..
on 07-07-2025 12:17 PM
Lucky you! My internet is still very much broken 😞
