EDIflyer
632 REPLIES 632
Nameless
Established
Just a quick check-in on the state of things
Have there been any changes for you all? From my end, some things are a touch more unstable than before when not using WARP
munk
No change here either, still seeing the same random pages failing to load.  Also noted that in Xbox when I try and start Diablo IV I can never connect to the battle.net servers on the very first attempt - it fails almost all the time (I think I've seen it load on the first go maybe twice in 50 attempts) - but always connects without fail on the second attempt.  I wouldn't be surprised if this was something to do with the issue here.
I remember seeing the issue rear it's head when I tried to login to the battle.net site in a desktop browser as well (and as I speak I tried it just this minute (loading battle.net) and I've got the usual PR_END_OF_FILE_ERROR error).
bytespider
Similar. A few docker images and Home Assistant wouldn't up date, after a speed test on a different device and a third attempt they magically started working.
Nameless
Established
A new month begins and the issues are still there for myself at least
Have there been any changes for any of you all?
Maybe this will be the month when everything gets fixed?
toaster
I had another tracing session with Three yesterday. This time they had a number of scenarios to run through.
I'm cautiously optimistic that they are getting closer to the root cause. I didn't get a timeline, but they said they would get back to me once they've analysed the data collected.
I haven't seen any change in the issues - it's been remarkably consistent for me over the last few months.
AlSeek
Thank you for you time on sessions with Three and your updates on what is happening, you do us all a great service!
munk
Still seeing issues here as well, noticed issues on the Morrisons app today when trying to checkout and the app would fail telling me I wasn't connected to the internet but a tap on the 'try again' link would instantly take me through OK.
Various pages in Firefox on Android on my phone failing to load but again with a refresh they instantly load OK.
bytespider
it happens far less often for me than it used to, and I was able to update Home Assistant without issue today.
bytespider
Have any of you started getting crazy lag spikes recently? 500-2000ms
I would have just said it was just the connection to the tower but recently it seems worse and its happening consistently when my kids start a match In Brawl Stars. Then it will be okay for several minutes then happen again.
Do we think this is tangentially related or not?
Nameless
Established
It probably is related as any packet alteration methods in use would increase latencies
