EDIflyer
632 REPLIES 632
lordmerchant1
The specific docker repositories I have the most difficulty with are ghcr.io and linux.io - not their http counterparts but pulling the image files themselves. Anybody else having this issue?
EDIflyer
Yep, lots of us unfortunately - OK when connected to a VPN though.
bytespider
This is a know issue vector, you'll see myself and many others also have the same issue pulling docker images from those domains.
lordmerchant1
The sites themselves work, I.e. browsing . My specific issues arises when I try to pull docker images. So I have this issue where I cannot update my software reliably as the connection is made and drops out before completing. I often have to sit and click "retry" several hundred times before I luck out and get a stable transfer. It's maddening. I've had three for approx 9 months and this has arisen in the past 4-6 weeks.
Midnight54
Established
Sounds like my issue running the DCS World updater initiating.  I have to refresh the web page til it loads then quickly launch the updater for it to start to download.  Thankfully the update is once in a blue moon, however I was also having joining games too on mp servers, but since broke leg been unable to play for now to test that in itself, so for now its casual gaming, and work from home, which thankfully is laptop and vpn else I'd have been unable to work at all.  Xbox app flat out will not load at all for me (but maybe perhaps still a PC issue for that one to give Three the benefit of doubt, but I'm going to tether to my work phone when I get a moment free to rule it out)
lordmerchant1
Do we think that running a VPN at router level and then passing using IP passthrough to said router would mitigate the CONSTANT linux.oi and give.io pull errors?
Nameless
Established
This would work in theory as VPNs and WARP are not blocked by Three
Not to be an annoying paper clip but do you mean https://www.linux.io/ and https://giv.io/? Both of those work for myself when using WARP
lordmerchant1
I'm unfamiliar with WARP
Nameless
Established
You can find out more about it here:
https://one.one.one.one/
bytespider
If your clients connect to that router with the VPN connection then I don't see why not. I considered similar but I don't have a router that can do VPN and the available machine to run such software is over a crappy power line adapter which would hurt performance even more than currently
