on 22-10-2023 03:21 PM
on 01-06-2024 08:52 AM
Nope, Nada, Not a Sausage. Thoroughly disappointed
on 30-05-2024 09:42 PM
With AkiTaiyo's help, modified the other script slightly and ran it last several minutes, ssl errors being logged successfullly now. Reddit for most part returns failures for some reason, but still gets SSL errors once in a while. I suspect that if I increase the delay between each check that the SSL errors might increase
Mostly been working over VPN today as had lot of work to do so not tested much of actual real life browsing, but the issue is definitely still there
30-05-2024 09:52 PM - edited 30-05-2024 09:52 PM
Increased the RequestInterval from 500 to 5000 to slow down between checks, and real-debrid is significantly worse for SSL failures right now - with 21 out of 44 requests SSL erroring, and 9 out of 44 so far for Santander
on 30-05-2024 10:22 PM
After running for some time with the much larger delay, almost 50% failure for SSLs on real-debrid. Santander seems to have waves where it gets several failures then is ok for a while.
wikipedia I noticed shows there fine on each test, but I accidentally clicked a google result that was a wiki link and actually had the error in the browser, so the errors are still actually there but not captured
on 30-05-2024 10:24 PM
and I need to add accounts.google.com to the list
on 30-05-2024 10:49 PM
Out of interest are others having issues with The Internet Archive?
For insecure (http://web.archive.org) I get the 3 Content Blocker message, for secure (https://web.archive.org) I get the usual ERR_SSL_PROTOCOL_ERROR 100% of the time.
on 30-05-2024 11:30 PM
In browser web.archive.org is working for me. I'll add it to the checker that I'm running. Current update on that is approx 40% SSL failures on realdebrid by tar the worst performing.
Probably reddit after that with a mix of SSLerrors and timeouts, then pinterest and Santander. This is with the 10x longer delay so has been over quite a period of time
on 30-05-2024 03:25 PM
Seems really bad again for me again today after about a week of very minimal issues.
on 26-05-2024 05:26 PM
I can't even do my Santander banking changing between pages cos the pages are constantly bombing out either with either the "retail.santander.co.uk unexpectedly closed the connection." or it bombing me back to the login screen that I have to go to my parents home to do it!!! Three / @JonathanB please when can this issue be sorted, its causing me huge issues with doing simple but important things such as banking, let along the damn inconveniences its causing between multiple websites. Why has there been no updates when this is a big problem!!!!!!
24-05-2024 09:07 PM - edited 24-05-2024 09:14 PM
If anyone is interested, I've made my app+source available.
It's hacked together in C# so feel free to make improvements on it. Requires .net8 to run the binary. Tries to categorize most of the errors (in a really dodgy way).
Gives you a readout like this on the console window, press "esc" to stop it running, but it doesn't save the results so you will want to copy/paste them to somewhere before closing the window!
Source + binary in zip format from my Google Drive. See the 'bin' folder for the pre-built binary.
https://drive.google.com/file/d/1xMaD4DJEGjJFUASdMI0ARnibB39Zru4H/view?usp=sharing
urls.txt file controls the sites it requests. Don't include the https://
Feel free to use + make changes, publish to github or whatever..
