on 22-10-2023 03:21 PM
10-02-2024 04:27 AM - edited 10-02-2024 04:28 AM
I am currently flying back to the UK on a Singapore Airlines A380 and their WiFi service just gave me the exact same issue when hitting GitHub
what’s the betting that their in-flight service uses Zyxel kit, or it’s related to some form of content filter.
BTW I see this problem with my second router, but that’s also a Zyxel FWA017 so probably has mostly the same firmware code
on 09-02-2024 12:40 AM
Hi, I've just created an account specifically so I can also add my comments on how this issue is ALSO affecting myself.
I use a three mobile broadband SIM in a Three branded NR5103E. I've been experiencing the exact same issues as all the other users in this thread. Multiple websites connections failing, "ERR_CONNECTION_CLOSED" github.com, diy.com, even topcashback.com is giving me grief. It's now got to the point where my connection is almost unusable, banking apps are failing requests and I have to click retry 3 or 4 times before it actually does anything. My octopus energy account isn't loading and keeps logging me out. It's absolutely ridiculous.
This all started around 2 months ago. I've been using this as my main internet connection for over 12 months and it was flawless up until that point. These issues were non-existent and nothing in my network setup has changed.
As it's now got so bad, I've had to take drastic action. I've added another router to my network and switched the SIM to it, for info it's the ZTE MU5001 mobile 5G router, and all my problems are now resolved! All websites are loading normally and functioning as expected.
Just to note, I haven't removed the NR5103E from my network, it's still being used to broadcast wifi, I've just disabled DHCP and I'm using the Ethernet WAN port. This proves that it's not an issue with the three 5G network, as I'm still using the same SIM and mobile network, the only thing that's changed is the gateway.
In my eyes it's clear as day that this is a botched firmware update for the NR5103E which has caused these issues. This is not an isolated incident, it's affecting a huge number of customers and is simply unacceptable! Either roll out another firmware update to fix the issue, or roll the firmware back to the last known good version.
I'll be keeping my network setup as it is right now, as it's actually usable for a change. But, I will monitor this thread in the hopes that Three eventually decide to take some responsibility for the issue and address it. My current setup is not ideal, it leads to slower speeds and higher ping as it's a mobile broadband router not designed for long term home broadband use.
Honestly, Three should be ashamed of themselves. Especially @JonathanB, who seems to be brushing the issue under the carpet, dismissing the issue and blaming the "Service Desks", whoever they are! This needs escalating to Zyxel technical support immediately and resolving as a priority.
on 18-02-2024 07:22 AM
Changing the router does not work. I've tried this few times. I used:
HUAWEI CPE PRO (3 different devices, with and without Three branding)
ZYXEL NR5103E (2 different devices)
ZYXEL NR5103EV2
I have access to many routers that's why I could give a go to so many of them.
On every one of them IT WAS DROPPING the connection, behaviour was exactly the same. I ordered LYCA mobile SIM (EE network) and hopefully that will solve the issue.
Three does not give a s**t to solve this problem
on 09-02-2024 07:05 AM
Very interesting that adding a ZTE MU5001 into the mix solves your issue.
While the majority of users on this thread are on the NR5103E, there are others who are using the ZTE MU5001 and still seeing issues. There's one mention of it happening on a Huawei H122-370 and I'm seeing the issue on my Huawei H122-373.
So, while the issue may be related to that version of the firmware on the Zyxel kit, it's strange that it also affects other brands of router.
For info, my H122-373 is on:
Hardware version WL1H122M
Software version 11.0.2.20(H329SP1C21)
Like others in this thread, the issues only affects me when I'm on a 5G network. When I drop to 4G the issue goes away - unfortunately, there's no setting I can find to always force 4G so I have to find increasingly shielded parts of the house to "hide" my router from the 5G signal - it always eventually finds it but I can sometimes get an hour of uninterrupted 4G use.
on 09-02-2024 09:37 AM
That's very strange indeed.
I've had no issues since changing to use the MU5001, my response time for loading websites is vastly improved and I'm using the 5G network. It's a Vodafone branded device, but unlocked, so works fine with Three.
My Software Version for info is: BD_VDFMU5001V1.0.0B05
Is your H122-373 Three branded or generic?
on 09-02-2024 06:43 PM
It's Three branded
on 09-02-2024 09:53 AM
I had this issue for many many months last year and I have the MU5001 with the same firmware version and Vodafone branded (it has never received a firmware update...).
The issue went away for me about a couple of months ago, it was prevalent before that and happened on basically every website I visited and I have a Three Business line. The only website where I encounter the issue still is on royalmail.com
My contract is ending shortly and I will be thinking about moving away because I need reliablity.
on 07-02-2024 10:43 AM
That isn't an answer, an answer would be why the service desk isn't proving you with an update, is it because there isn't one? Do were now have another 4 month wait?
on 06-02-2024 05:04 PM
Hi everyone,
I'm sorry for the lack of updates on this issue. I'm chasing the service desks on this, and I appreciate it's been a long time since any progress has been reported around this. I'll let you all know as soon as I have any more advice or info.
on 07-02-2024 10:47 AM
I think you need to escalate this much higher than the service desks, @JonathanB - this is becoming a pretty major issue for multiple customers now.
