EDIflyer
571 REPLIES 571
Nameless
Established
Hello and thank you for your post
If you have not done so already, please make a quick note of all of your settings including the router model and the band selection (If set to auto, please record which bands you are connected to at the time you check)
Do you have any websites which would normally cause the PR_END_OF_FILE_ERROR to appear? Even if it is a random occurrence, I would like to add them to my list for testing as I still have not found a website which will always fail however those websites in the list have been mentioned as failing at some point in this very long forum thread...
Also, can you please confirm that you are definitely connected to the 5G network? You should be connected to an N band (N78) as well as at least one B band. This is to rule out a highly performant 4G connection as I am led to believe that it can reach a speed of ~150Mbps
x-c311
Zyxel NR5103E
It is tricky as it can be bit random. It often happened when I went to https://www.hotukdeals.com/  then clicked on a deal for amazon. The browser goes to some affiliate link first which would give the connection was reset error then continue.
x-c311
My old mast is fixed so getting fast downloads again, but 6 hours in and got my first connection reset error. When browsing www.hotukdeals.com then clicking on a deal for epic games store. Also the other normal symptoms, netflix takes ages to load, some apps fail to open and then work the 2nd time.
Hi @x-c311,
Thanks so much for this feedback. I'll pass this on to the team who are investigating in case it helps solve this. I'll let you know if there's any more info we need to check this out.
Hi @x-c311,
I've sent you a PM to request a little more info so we can add this to the investigation.
Nameless
Established
Did I miss a check-in this week?
There was a moment earlier this week when the B3 band kept dropping out and the B1 band was not chosen despite having a better signal most of the time so I had to disable the B3 band to force the router onto the B1 band
Apart from that, I am still recovering from the hard drive loss and accumulated backlog due to that and have not done as much testing however there have been no noticeable changes...
How have things been for all of you?
torz77
No change. Still abysmal
andym00
So, around the 30th of October I reported here that things seemed to be working for me fine using 5G at home suddenly and out and about locally using 5G, and as I later discovered when back in the office one week the cell tower near the office was now delivering working 5G, whereas before that was a fail.. And also, every 5G tower I was connected to was working fine, though during this time I haven't ventured very far, maybe only a 10 mile circle over this period, but all has been absolutely perfect, not one connection error..
And that has been the pleasurable case since then.. Up until Wednesday last week..
It's now back to exactly the same weird behaviour as before, with apps galore failing miserably all the time, Netflix won't login, MS Authenticator doesn't want to know over 5G, banking apps erroring, gmail failing to refresh etc..
I don't know what Three changed in the region for that 5-6 week period, but please change it back again!
I can post the two cell towers that I can 100% vouch have been working fine for this period, and I don't believe you can't determine what was changed on those two towers from a software/hardware perspective, around the window of everything functioning perfectly..
Nameless
Established
If you have not done so already, send @JonathanB a direct message about this and I hope that this gets forwarded to the relevant departments quickly
I have not been lucky enough to have seen any significant changes where I am
Hi everyone,
Thanks for your patience. As I mentioned on the last couple of updates, we'll be running some further live traces soon. We've got this planned in for next week, so I'll hope to have a more significant update later next week.
