EDIflyer
572 REPLIES 572
Hi everyone,
Thanks for your patience. As I mentioned on the last couple of updates, we'll be running some further live traces soon. We've got this planned in for next week, so I'll hope to have a more significant update later next week.
Nameless
Established
Thank you for your update this week and thank you for continuing to issue weekly updates for us all
Between my last message and this message I can still confirm the following:
  • Disabling Band B3 causes the issue to become rarer for myself
  • The issue still exists
I will continue to test things from my end
Nameless
Established
Last week was fun - I lost a hard drive to mechanical failures and have now just remade the bookmark folder with the 100 or so problem websites reported here (Yes I did go through all 509 messages before this one)
With that being said, I have not had an opportunity to do some extensive testing recently due to my almost complete lack of PC usage and will start later today
How have things been for all of you?
bytespider
I've seen no significant change.
Hi everyone,
Just to update you all, I'm waiting on more info about our next set of live traces from some internal teams. I'll reach out to everyone who has expressed interest as soon as I have clarification on the timeframes and how this will be set up.
BrAinZ
I was having loads of issues with various things that needed to connect to the internet. I went through the guidance to turn off IPv6 and am now only using IP4. Fixed quite a few things, but still have issues with some sites. Very annoying if you want to buy something at Screwfix.co.uk as that just never works unless you go through a VPN, in which case it works fine.
Hi @BrAinZ,
I'm not sure if this is the same issue on the screwfix website. That's https://screwfix.com right?
Have you removed adult filter from your My3 account? I've seen a few instances where similar SSL errors do get returned by the filter triggering, and screwfix is likely to trigger the filter due to some of the age restricted items they sell.
From my understanding, there's not been any websites reported that always return these errors, these have always been reported as intermittent, although they can vary in frequency considerably. Does every attempt to connect fail, or do you mean that the errors are preventing you from completing an order in their shop/checkout processes?
Nameless
Established
Just a quick check-in with no changes
There have been no significant changes - Wi-Fi or Ethernet, everything is the same
Have there been any changes for yourselves?
bytespider
No change here. Experienced the issue just today on scummvm.org
Nameless
Established
I will add this website to my list of testing sites - 99 websites in my list and counting
As far as my testing has shown thus far, there is no website that is immune from the problem however some of those mentioned in this thread do seem to generate the problem more often when using certain bands...
