on 21-11-2022 09:11 PM
I have recently got the 5g hub and am finding that devices connected to it via ethernet cable are really hit and miss whether they find the network. Keep getting errors such as cable isn't connected. Cables have been checked on another router and work fine. Is this a known issue?
on 23-11-2022 03:01 PM
Hi @Dazzar, thanks for confirming this info again but the questions I've asked are directed to the OP @Stimpakman. We'll need them to answer too, in order to see if there's any correlation with the issues you've described.
on 24-11-2022 04:00 PM
@JonathanB Yes I realised this when I clicked send
on 24-11-2022 04:55 PM
No worries @Dazzar,
I've sent you a private message earlier to ask for a bit more info about the issues you've been facing with the ZTE router.
on 22-11-2022 09:32 PM
Hi what router do you have ? I’m having problems with the ZTE801a that keeps dropping Ethernet
