on 15-03-2025 04:26 PM
I just upgraded to the MC888A home broadband but now a number of my devices won’t connect as they are not 5g compatible. I was looking online and saw that some wifi extenders can split the signal into 2.4 and 5g. Can anyone confirm this and/or give a suggestion for one so I don’t have to buy multiple new devices
on 16-03-2025 09:56 AM
Hey, Bartimus.
I've never come across a device that's actually incompatible in this way. All the examples I've seen myself or where it's been mentioned by others are actually just manufacturer oversights. They detect the phone connected to the 5ghz band during set up, and then tell the user they can't set up the device because it's compatible with 2.4ghz only, even though the network has a 2.4ghz band as well.
Most manufacturers fixed those limitations within their setup processes so that the apps just give you a warning or reminder, then they continue on to complete the set up. There's a couple of different ways to work round the ones that still have issues. You can alter the settings in the Hub to disable the 5ghz band temporarily, then set up your devices, or you can set the phone to not use the 5ghz band if the phone allows you to do that. Once your devices are set up, you can put things back to normal.
Another possible way to avoid the issue, but it's one I wouldn't really recommend for most people, would be to change the SSID name of the 2.4ghz to something different than the 5ghz one, and this would stop setup issues like this from happening in future, however it also means your devices won't roam between the bands as smoothly as they used to. For example, if you went to an area of your house where the 5ghz didn't reach you, your phone/device would switch to the 2.4ghz network which has the other SSID. Once it does that, it would not switch back to the 5ghz network again unless you went into the settings manually and changed it every time. The same would happen for any other devices that move around. Quite frustrating.
on 17-03-2025 08:24 PM
I’m specifically talking about a PS4 and a baby monitor that were built before 5g was ever a thing. So are you saying it is possible with my particular router to split the signal into 2.4 and 5g?
on 18-03-2025 11:52 AM
Hi @Bartimus,
I don't have access to a router to test, and I haven't been able to find a walkthrough for the MC888 specifically, but on our previous ZTE 5G router, there was an option like this in the Admin settings, can you see this or similar:
A single merged network is usually best as Pete was saying, but generally you should be able to unmerge to separate networks for each frequency for device compatibility issues like this.
Alternatively, for the PS4 you could use a wired connection via ethernet if this is practical. I'm assuming a wired connection wouldn't be a solution for the baby monitor though.
Let me know if either of these suggestions help point you in the right direction to solve this.
on 15-03-2025 07:40 PM
Many broadband routers have long offered split frequencies; just search the internet.
