Not Sure If I Have 5G Connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 06-06-2023 09:56 PM
Hello. I`ve just got my new NR5103E Three 5G router. Set up was simple. However, with the Three mast in clear site about 1/4 mile away, the modem only displays solid green light on the router. No white light for 5G.
These are my stats for WAN:
- Labels:
Home Broadband
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2023 11:09 PM
I think you mean blue light to 5G (on the globe symbol)
If you look at your stats, you will see access technology states "NR5G-NSA" - see the 5G.
also 4G tops out at 150mbs
are you getting the 5G showing under "system status" in the app, or 5G showing under systemm infor if using the web interface (first/front screen)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 08-06-2023 12:31 PM
Hi, From the info you have provided, there's excellent 5G service. n78 is the 5G band and it displaying two of them is that your location is in reach of two cells on that mast I believe. Is the connection reliable? Is the router in the best location?
5G speeds vary considerably. A test you can do is limit the router to just 4G and see what the speeds are and also check the icon colours.
Strange the status light is green and white. It should be blue for both the Internet connection (globe icon) and Cellular signal strength (3 bar icon). Which icon is showing white?
