on 06-11-2024 09:40 PM
Hi there,
We have been very happy with our 5g home internet until now, getting speeds of >500mbps.
The other day there was a power cut in our area that affected everything including it seems the nearby 5g cell tower. The power cut lasted about 2 hours and after this the internet came back. However, since then we have not been able to get speeds greater than around 15mbps. We've restarted the router many times and even on our phone that uses the three network the same has happened. Is it possible the power cut has affected the nearby cell tower and so our internet speed?
on 09-11-2024 01:08 PM
There isn't anything we can check here, sadly. The Support Team should be able to shed more light on the situation, and might be bale to provide options for you depending on what's going on.
07-11-2024 10:00 PM - edited 07-11-2024 10:03 PM
on 07-11-2024 08:22 PM
No reported issues on the checker unfortunately. The speeds have got a tiny bit better today, e.g. now getting around 30mbps down.
on 07-11-2024 12:40 PM
Hey @rburton,
Oh no, I'm sorry to hear your speeds have dropped drastically since the power cut. It sounds like it may have resulted in an issue with the local mast if it's impacting both Home Broadband and mobile coverage.
Have you had a look at our Network Status Checker? Does it show any reported issues or work going on in the area?
Kate
on 08-11-2024 11:24 PM
The internet is just unusable right now, is there anything you're able to look at to see what could be causing the problem? Everything has been amazing with Three until now.
on 09-11-2024 07:03 PM
Thanks i'll get in contact with them.
on 16-02-2025 09:56 PM
Was there ever a solution? This happened to me, except there was no power cut, and the download speeds are around or below 1mbps
on 17-02-2025 07:34 PM
Hello, Rumboe.
If you haven't tried already, it might be worth doing a factory reset of your Hub, just to make sure it's a fresh start and any possible configuration issues or bugs are cleared.
It's also perhaps worth checking the Service Status page before hand in order to see if there are any issues locally that might be causing the problem.
