on 01-22-2024 09:36 AM
I just took out a 4G home broadband contract as my FTTC is so unreliable and there's no sign of fibre to prem here anytime soon.
Initial testing looked good - around 120-140Mbps...
However, I've since run into a few issues:
I've tried using three.co.uk as the APN as suggested in other threads, but there was no improvement to speeds.
Just wondering if there is a fix for these problems, if anyone else has had the same experience? Otherwise I'm going to have to return it and wait for FTTP to arrive 😞
on 01-22-2024 03:28 PM
Hi Pete,
Thanks for your reply, I thought there's probably not much to be done.
It's a bit baffling that Three ship such poor routers with a home broadband service - I can't imagine it works well for many people in an average-sized house. It's a shame because in the same room as the router, I can get 150Mbps+
on 01-22-2024 12:21 PM
Hello, Joe1.
It sounds like the cellualr network side of things is running OK, since you can get a good connection at 1 side of the house. The issue that sticks out here then would be the WiFi side of things.
It's unlikely that the WiFi signal strength would increase or improve as a result of anything done on Three's side. If the WiFi is at its limit, its at its limit. You could try extending the WiFi networking using a wireless or wired extender. This would allow you to increase the WiFi coverage while leaving the router in the optimal position within the house.
