on 25-10-2022 01:01 PM
I have a HTC Explorer and use Pay as you go inherited long ago from Vodaphone but now on 3. Having problems with lack of signal so tried Wifi Calling - or would have done IF it was on phone.
Can an HTC Explorer use WiFi calling as cannot find anything about it on my one?
on 25-10-2022 08:29 PM
Pretty sure the answer is no, cannot find any info on the subject for your phone. Does HTC still exist and even if it does it's unlikely that anyone will make any firmware mods for the phone.
on 26-10-2022 10:18 AM
Think you may well be correct - thanks
