23-02-2023 11:41 AM - edited 23-02-2023 11:45 AM
I got my 5g hub in August last year. ZTE mc801a. It has worked perfectly.
However over the last week the signal bar is frequently dropping to 1 bar, and my speed test is maxing out at 5mbps.
I've tried multiple locations but it is still the same. Nothing else has really changed - no new devices etc. There is construction happening down the street but that's been going on for months.
Any advice?
on 23-02-2023 11:50 AM
Hi, first place to go is here:
Network Status Checker - check your signal and get support | Three
If no issues you can try customer services on 333.
