on 03-01-2023 05:16 PM
If I forward all my calls to my UK Skype number (or another number), will I get charged while roaming ?. I need to turn on my phone while roaming to receive SMS messages
on 06-01-2023 05:22 PM
Hi @Laz,
You can divert to voicemail for free but other numbers will count as an outgoing call, so it's best to double check the roaming rates for the destination before setting this up.
Hope this helps,
on 26-05-2024 04:22 PM
I mean three Voicemail where it says voice ail**
on 25-05-2024 07:08 AM
In addition to the questions above - do Three have roaming bars that we need to remove - or the only settings we need to check on the phone? Years ago we'd have to call to have bars removed - is that still the case or is it just the spend cap?
