Calls and coverage
Cking200122
Hi is anyone having trouble today with calls taking a while to connect and sometimes won’t connect plus if someone calls you it sometimes dose not go through and signal dropping
mile cross Norwich area?
5 REPLIES 5
Lee252
Yep, exactly the same
Hello there.
There's a few things worth looking at/considering. The first is Wifi calling. This is designed to offload network services onto Wifi whenever it benefits the user. In some cases it can cause issues though. Once way to rule it out is to turn off Wifi calling, and then see if you still have the issue. Another way to test would be to go into Airplane mode, then ensure your Wifi is on, this will force Wifi calling to be active and test again. If your issue goes away during the first test, it could point to your Wifi connection not being ideal for Wifi calling features, and the feature should be left off. If the issues go away during the 2nd test with Wifi calling being the only connection, it could point to an issue on the mobile network side of things.
To check out the mobile network side of things, you can use the Service Status Page, which will give you an indication of how things are in the area.
If non of these give answers, you may have a device issue. You may want to try resetting the network settings within the phones reset menu. You could also look at replacing your SIM card. If your phone supports eSIM, you can do the swap quickly without any down time and without having to go to store to store.
Lee252
I’ve tried all that and didn’t work
Hi @Lee252,
I've sent you a reply on the other topic you started, but I can see now you've posted about this here too. If you can let us know in a bit more details what's happened when you've followed Pete's advice this will hopefully help us narrow down the issue.
For example, did the Network Status Checker show we're aware of and working on any issues?
Does the issue happen on both Wi-Fi calls and normal calls over the mobile signal?
How long has it been since you swapped to a new SIM, did you get a new physical SIM or eSIM?
Clever-Trevor
Hi, that was always happening to me - on longer, say 30min+ calls ( very frustrating) . I moved my main line to EE, never have that problem now….
