on 09-10-2024 08:31 AM
Hi. This issue is driving me nuts!! My Internet works fine. My local LAN is the issue. On my laptop, wirelessly, I try to connect to my NAS but sometimes it connects and other times it times out. On wired connection to router, all is fine. so wireless is the issue. It`s so random. Reboots of laptop, disabling wireless and re-enabling sometimes fixes the issue but not always. Leaving it 5 mins sometimes helps connect. I`ve updated my network drivers, firmware etc. on NAS and disabled all firewalls. I`m sure it`s the Router and the wireless routing side. Anything to look at here. BTW, I tried static IP`s and all that. Changed APN to three.co.uk etc.....HELP! Ready to ditch Three for Virgin......
on 10-10-2024 08:06 AM
Ignore!! Need to brush up my networking skills. I had a switch on wrong subnet. All sorted now. Sorry for wasting peoples time.......
