on
05-08-2024
10:45 AM
- last edited on
05-08-2024
07:42 PM
by
Hi
I live in Post Code Area NE2* *** and all morning there has been either no signal or a very very weak one with only 1 bar showing on the signal strength. Normally there is a very strong signal with all signal strength bars showing. Is there any works being carried out that someone knows about as I need a good signal due to my health condition. I do have WiFi calling but unfortunately I have always found it not to be very reliable when used in the past.
Cheers
Smudge
on 05-08-2024 10:47 AM
I can't believe it, I have just posted this and the signal is now
showing at full strength again
on 06-08-2024 11:48 AM
Hey @Smudge,
Glad to hear this has improved, if you're experiencing any future issues, the best way to check for any known issues is with our Network Status Checker. We've removed the 2nd part of your postcode, just to be on the safe side, as this is a public forum and it's best not to share personal details like your home postcode.
