on 06-04-2023 03:12 PM
on 06-04-2023 03:55 PM
Hi, Nigeria is not on Go Roam list so call and data are all charged for. Have you turned on roaming?
International roaming will be activated automatically on your account. You can double-check your roaming settings in your My3 account on your computer or on your phone:
You'll also need to make sure that data roaming is turned on in your device's settings if you want to use data abroad.
As all calls and data are chargeable it is best advised to check your spend cap. I think it is set a £50 but check. Also, I think, if you have an outstanding balance then this may be considered part of you spending cap so no credit left my mean no calls.
Next if all of the above is okay your phone may not be automatically selecting the network. According to 3's website your options are: Etisalat and MTN Nigeria (no texts with MTN). You can manually select the network by going to phone settings, connections, mobile networks and Network operators.
I hope that something here helps.
