on 29-11-2024 10:24 AM
Hello,
I've just upgraded to the 5G Three mifi device mobile broadband and when I try and enter the network password from the back of the device, i keep getting a message saying 'incorrect password'. I have tried everything and it still will not accept the password. Please can anyone adivise?
Many Thanks
on 29-11-2024 04:52 PM
Hello, Katsz.
Is it the password for the Wifi network that you are trying to enter? If so, keep in mind these are cases sensitive. If you still can't log in, I'd recommend trying a factory reset of the hub, then trying again. If you still don't have success at that point, I'd try using a different device to connect to it, just in case the device you're using now is having issues.
