on 11-11-2024 11:23 AM
on 17-12-2024 05:14 PM
Hi @CMCMANN,
Sorry to see there hasn't been any other response to your post. Did you purchase and test a booster in the end, if so how did this turn out? It sounds like you were referring to the Home Signal devices we supplied for 3G signal over 3rd party Broadband connections. I don't think this is precisely the same type of device as those were technically a small Three cell (sometimes referred to as a femto cell).
We don't supply devices like these boosters, so I'm not in a position to recommend them, but did you go ahead with this, or find any other solution? Generally the recommended option for poor indoor signal is to use Wi-Fi calling which supports calls and texts, and as you'd have Wi-Fi coverage in that situation this takes care of Data.
