Split CLI on Porting number
SomersetChap
I recently ported my number from Lebara and received a text confirming it had all gone through… Happy days, so I thought.
Made a test call and all good as showed my ported number correctly.  Sent a test text and this is where I am having issues.
When I text, it is showing the temporary number from three. Checked my iPhone and under settings it does show the temporary number along with iMessage etc. Turned all those off and tried editing the number to no avail. Restarted the phone, forced onto another network and back, no change.
Chatted the Three via Online chat and phone but no-one could solve it although someone said that it was being ported tomorrow (hmm).
Not sure where the issue sits as phoning is fine and seems to be a SIM update or something to force the phone to give me my ported number back on the device for texting.
Any ideas as a tad frustrating this one.
SomersetChap
SOLUTION - This fixed my issue on my iPhone and thought I would share around.
Not sure if required as a pre-req but I had switched off iMessage & FaceTime.
I went into SETTINGS - GENERAL - TRANSFER or RESET IPHONE - RESET - RESET NETWORK SETTINGS.
This cleared all my WiFi passwords on SSID’s like home WiFi etc but after it restarted, I was able to go into SETTINGS - PHONE and change the number to my ported number.
I then re-enabled iMessage and FaceTime and all now working correctly.
Thanks to all those that contributed in the community. It’s great to see.
18 REPLIES 18
kbf
Have you managed to get this issue resolved? Having the same issue going on for weeks. Losing hope.
KateS
Hey @SomersetChap,
Oh no, that sounds super frustrating. I'll do my best to help here.
When you go to Settings - 'Your name' - Sign-in & security - Edit, does it let you add your transferred number?
Can I also check what date the port-in was scheduled for, please? Also, when did you activate the SIM?
Kate
SomersetChap
Hi Kate, thanks for your comments.  Yes, I can add my ported number under ‘sign in & security’, however, it says it’s unavailable for IMessage & FaceTime.
The SIM was activated on Tuesday 16th and received a text saying it was ported on Wed 17th. It is VERY frustrating as friends and family are getting ‘undelivered’ messages which is concerning as one of my parents is in hospital 😔.  I have had 3 people from Three look at this but all told me that I have to wait for the porting to be completed but told them I have received the text it was completed. It feels like the SIM needs to be told the new number but I am sure the this has already been checked by Three.
Any assistance to get this resolved would be great.
SomersetChap
Antony1
Thanks worked for me December 2025
Vik797
This definitely works! Thank you.
Mmet
Wow I’ve been up all night in my settings trying to figure out why my new number isn’t working. This worked perfectly for me in October 2025. Thank you!
MrBal85
Perfect! This worked for me in August 2025!
Thanks for confirming @MrBal85, great to see that this is still a helpful topic 🙂
