07-09-2023 02:49 PM - edited 07-09-2023 02:52 PM
I'm a little bit confused. On the 3 Home Broadband App it says that I have -90dBm coverage which relates to an 'Excellent' Signal. However the broadband seems quite poor compared to experiences of others, as well as my own Phone 5g speedtest from O2, which is meant to be far worse than 3 compared to speed apparently. I chose this contract as it was very cheap as well as boasting a minimum of 150mbps (which I am getting less than half of that). Also because the fixed line broadband that I was receiving was only around 30mbps and very poor (even compared to this).
I'm just looking for tips and tricks for, helping wifi coverage around my home (such as recommending mesh wifi / installations of ethernet ports and access points (such as which is the best way if mesh wifi is unreasonable). As well as ways to help increase the signal speed from the cell tower
Here is my current setup:
- using the internal antenna from the router
- not connected any clients via ethernet as the router is positioned for best signal, not ease of use for connecting ethernet devices.
- uses the included wifi router, no external or wifi mesh (wifi signal is poor in some places)
I would prefer my solution to match the following:
- If I was to get an external antenna, it would have to be the right price to performance, as well as to be mounted inside the loft only. (I know where the cell tower is, so I could have a directional antenna if appropriate)
- If I was to purchase a mesh wifi, it would have to be at the right price to performance. In addition if I was to do any home wiring I would like it to all lead back to the loft where I would prefer the network setup to be kept
- Would prefer any solution to be perfect with little disruption.
In addition, all of the settings for the router are kept default. What would be the best settings to change, such as the band (and how could I find the best one).
TIA,
superfast5gpls
on 07-10-2023 11:17 AM
Hi thanks for your response, I have the most recently Three 5g router (the white box looking one).
on 07-11-2023 04:57 PM
Hey @superfast5gpls,
Is it the same model as the image you shared? That's the Zyxel NR5103E.
on 07-12-2023 10:08 PM
Hi yes it is the one that is on the photo.
