Home broadband mobile wifi
Ashers190
Hi there just wondering I'm going Blackpool at weekend anyone know if I can take my mobile broadband with so get bit of piece and quite during conference breaks
2 REPLIES 2
Hi @Ashers190,
By all means, there's no requirement to specifically use the router at your home address. You may wish to check the local coverage in the area you'll be visiting to make sure there's 4/5G signal.
Geluk
Key player
Answer in the name, "mobile broadband"; and that'd be "peace"!
