EDIflyer
567 REPLIES 567
EDIflyer
Certainly in my experience what tends to happen on a smart TV is Netflix, Amazon Prime, etc. fails to load. It might start and have empty boxes that then don't get filled in. I normally have to manually kill the app and go back in, sometimes a few times. It would seem to be from the same closed HTTPS connection but without it being able to report the same thing.
Nameless
Established
I also experience this kind of issue with the Amazon Fire TV
x-c311
Just as an update this is still ongoing for me since my local mast was "fixed". I have changed the bands as suggested and I would say it helps a little but there are still issues. I know this going to be difficult for others to test but it really affects my app for my ecovac robotic vacuum.  Pretty much every time it says offline then I have close the app are retry and it then works.
Daily reboots of the router also helps I think, it don't believe it's a router issue as I have tested 2 different models. Its more to do with long you have been connected to the mast.
To do further testing I'm now running on 4G only just to see if I get the same issues.  My 4G is pretty good tbh, 250Mbps down, 36Mbps up.
Nameless
Established
Thank you for your update and testing
I have just completed some testing and I can confirm that the issue is still there and random although mast connection duration is something I have not tested for before
The most I can say in regards to connection duration from my observations is that the usual connection errors do not seem to change in a noticeable way although, after months of testing by constantly changing things and resetting the router, I have been testing lately without resetting the router so I can test for X many days since restarting the router (44 days so far)
As far as I last checked, I did not see these issues on 4G alone however paying for a 5G service when restricted to 4G is not value for money and should at least be a discounted option that is available
I will do some more testing of 4G alone when I can
x-c311
I completely agree that using 4G is not an acceptable solution but I've got to the point where I'm so fed up of the constant errors and unknown of is this app broken or is my connection, that the reduced download speed is the better option.
The other day my daughter installed a new game of her handheld but she had played before so wanted to pull down her save game from the cloud. But the game kept reporting the servers where down so couldn't play. But where they actually down, who knows, unlikely, the next day I tried again on 4G and it worked fine.
Just fed up of it now
Sorry for errors on a mobile
x-c311
Hi all,
I've had this problem for the past year, and tried all sorts of things to fix, different DNS, APNs. Different SIMs using the three network, 2 different 5g routers. A reboot sometimes helps but only lasts a few hours before I see the same error creeping back.
Interestingly however my local mast is currently broken eNB ID 5548. I complained to Three a week ago about it as it gave 5G signal but no internet. In any case they now appear to have turned it off, while they fix it I assume!? Because now all my 5G three devices connect to eNB ID 4603 which is about twice the distance. I still get 5g but 1 bar. I get about 150mbps compared to 650mbps before. However 3 days now and no errors, no connection reset no SSL problems, nothing!
Therefore it would interesting to see what the difference is between the 2 masts, well was as its off now. I mean to be honest I'm hoping when they fix it, I hope I don't get these errors anymore! Just thought it might make an interesting comparison.
Nameless
Established
Hello and thank you for your post
If you have not done so already, please make a quick note of all of your settings including the router model and the band selection (If set to auto, please record which bands you are connected to at the time you check)
Do you have any websites which would normally cause the PR_END_OF_FILE_ERROR to appear? Even if it is a random occurrence, I would like to add them to my list for testing as I still have not found a website which will always fail however those websites in the list have been mentioned as failing at some point in this very long forum thread...
Also, can you please confirm that you are definitely connected to the 5G network? You should be connected to an N band (N78) as well as at least one B band. This is to rule out a highly performant 4G connection as I am led to believe that it can reach a speed of ~150Mbps
x-c311
Zyxel NR5103E
It is tricky as it can be bit random. It often happened when I went to https://www.hotukdeals.com/  then clicked on a deal for amazon. The browser goes to some affiliate link first which would give the connection was reset error then continue.
x-c311
My old mast is fixed so getting fast downloads again, but 6 hours in and got my first connection reset error. When browsing www.hotukdeals.com then clicking on a deal for epic games store. Also the other normal symptoms, netflix takes ages to load, some apps fail to open and then work the 2nd time.
Hi @x-c311,
Thanks so much for this feedback. I'll pass this on to the team who are investigating in case it helps solve this. I'll let you know if there's any more info we need to check this out.
Type a product name
