EDIflyer
502 REPLIES 502
bytespider
oh I'm aware I just thought it was funny, since we're talking about connection issues
EDIflyer
So after thinking things were going well (no issues for the past few days), I then had issues accessing web.archive.org today.  I was getting the usual "unable to provide secure connection" message -
Switching on a VPN fixed the issue as usual.
When I switched the VPN off I then got a different error:
However I had already disabled content filtering previously, about a year ago!
I therefore went into plan settings and indeed the "Allow Adult Content" option was indeed off. I switched it back on, provided a credit card number and received a text confirming it had been set:
I then tried again in a fresh browser - same error - however when I go back into my account the filtering is definitely disabled and adult content is allowed:
I'm not sure what is going on but sadly after getting my hopes up it is definitely not fixed!
At first I thought the script wasn't picking it up as it showed success, but I realised I had just put in "web.archive.org". Changing it to "https://web.archive.org" showed 20/20 errors...
Testing: https://web.archive.org
Attempt 01: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 02: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 03: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 04: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 05: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 06: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 07: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 08: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 09: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 10: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 11: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 12: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 13: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 14: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 15: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 16: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 17: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 18: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 19: Error - error:0A000419:SSL routines::tlsv1 alert access denied
Attempt 20: Error - error:0A000419:SSL routines::tlsv1 alert access denied
SSL Errors: 20/20
AkiTaiyo
This may be due to Threes adult content filter.. I've just tried archive.org and found out they have turned mine back on..
Requesting the http version redirects correctly and returns a correct status code 200, but from the wrong URL..
AkiTaiyo
Oh yeah, you said this in your message.. should have read the whole message..
EDIflyer
Haha yep - weird how it switched itself back on like that!
bytespider
I think the adult content switch on the plan page is a whole other bug as I was able to view adult content, check the switch and it said that it was off. So I toggled it on, and still able to view it.
bytespider
Even 7 hours later adult material still can be accessed, so that toggle does nothing.
Midnight54
Established
IIRC when I first got my router,it took either 24 or 48hours from requesting it to being able to access your favourite content 🙂
bytespider
My favourite content 🤣
I don't think they should have any restriction at the ISP level it should be something at the router level. Like Eero, Adguard, and PiHole. But we digress.
AkiTaiyo
Interestingly, this is redirecting even though my setting is set to allow adult content..
