EDIflyer
480 REPLIES 480
Midnight54
Established
Tried to download from the top right icon direct from the main link but get the following message on the page
"Sorry, this file is infected with a virus.
Only the owner is allowed to download infected files"
AkiTaiyo
Lol, ok..
GDrive doesn't like the binary so here's the source only version.
https://drive.google.com/file/d/1xPegW545CZ8V4nMw7h1ARhRhKZpbtLvn/view?usp=sharing
Midnight54
Established
Thanks - downloaded - of course I've no idea how to compile it - so guess time to google and download visual studio 😄
Edit : downloaded VS Studio and Net extras, loaded in VS Studio and Built, now running 🙂
Midnight54
Established
Hmmm not sure how to interpret whats going on with the results.
Reddit itself appears to be for the most part working despite the result sayin GenFail, but almost all the results are suggesting no issues, yet I'm having loads of issues today, especially with duckduckgo
AkiTaiyo
Like I said, the detection of the SSL drop error is dodgy.. relies on a text comparison which isn't necessarily going to stay the same across systems, but it was working for me untill the problem stopped..
I can't reproduce the fault on any platform or software tool  here, so I can't find a better way to track the error..
GenFail counts are when the there is a reply, but the status code isn't 200 (or "too many requests)
If you're interested in digging further into this the feel free to DM me and I'll send some other code to try, no point fault finding this on forum.
Midnight54
Established
I can't even do my Santander banking changing between pages cos the pages are constantly bombing out either with either the "retail.santander.co.uk unexpectedly closed the connection." or it bombing me back to the login screen that I have to go to my parents home to do it!!!  Three / @JonathanB please when can this issue be sorted, its causing me huge issues with doing simple but important things such as banking, let along the damn inconveniences its causing between multiple websites.  Why has there been no updates when this is a big problem!!!!!!
bytespider
Seems really bad again for me again today after about a week of very minimal issues.
Midnight54
Established
With AkiTaiyo's help, modified the other script slightly and ran it last several minutes, ssl errors being logged successfullly now.  Reddit for most part returns failures for some reason, but still gets SSL errors once in a while.  I suspect that if I increase the delay between each check that the SSL errors might increase
Mostly been working over VPN today as had lot of work to do so not tested much of actual real life browsing, but the issue is definitely still there
Midnight54
Established
Increased the RequestInterval from 500 to 5000 to slow down between checks, and real-debrid is significantly worse for SSL failures right now - with 21 out of 44 requests SSL erroring, and 9 out of 44 so far for Santander
Midnight54
Established
After running for some time with the much larger delay, almost 50% failure for SSLs on real-debrid.  Santander seems to have waves where it gets several failures then is ok for a while.
wikipedia I noticed shows there fine on each test, but I accidentally clicked a google result that was a wiki link and actually had the error in the browser, so the errors are still actually there but not captured
