on 10-22-2023 03:21 PM
on 11-19-2024 04:33 PM
Or in my case, left for another ISP 🙂 However, I'm still following closely, as family are still affected, and remains to be seen what happens when my next contract is up to if ever resolved
on 11-18-2024 03:39 PM
Another check-in with no changes
The incidence of the error is still highly variable but it is still there
Have there been any changes for yourselves?
on 11-12-2024 09:24 AM
Hi Everyone,
Just a quick update to confirm we're still investigating. I hope to have some more substantial news for you soon. I've also passed on the info provided here about manual band selection in case it helps point to the cause or solution of these issues.
on 11-11-2024 01:20 PM
Just a delayed check-in due to a busy weekend
There have been no changes from my tests - Having Band B3 disabled does still lead to reduced instances of the usual error message in my tests
11-05-2024 02:08 AM - edited 11-05-2024 02:15 AM
Ok, I ran 100 requests to https://docs.pi-hole.net on bands B1, B3, B20 and B28 (the bands I can find listed for my cell tower). I looped through these bands twice. I cannot see anywhere that N78 is an option I can change, or is listed for my cell tower, but it is very possible this is just down to me not understanding how 5G infrastructure works.
The number of failures per 100 requests are as follows:
| Band | Run 1 | Run 2 | Average |
| Auto (Main: B3) | 24 | 9 | 16.5 |
| B1 | 26 | 35 | 30.5 |
| B3 | 28 | 14 | 21 |
| B20 | 37 | 10 | 23.5 |
| B28 | 32 | 9 | 20.5 |
The tower details are:
For me at least, and accepting that this is a very small sample size, I would say that these results fall well within the range of natural variance, and changing bands has zero impact on my issues. Note that I ran the tests in the following order:
which suggests that the fluctuations are down to other external factors rather than the selected band.
on 11-05-2024 05:26 PM
Band N78 is responsible for 5G speeds - Without it you will be limited to 4G speeds only
If you can access your router's setting directly, you should have an option to either change the bands directly and, if that is not available, an option to switch between 4G and 5G networks with Three's 5G network being the NR5G-NSA type due to also needing a 4G band to work
I have added the website you have used to my long list of websites to check and, if you have any more websites that usually have errors, please mention them here as some websites seem to be more error prone than others and for different users
Thank you for performing your tests
11-04-2024 08:29 PM - edited 11-04-2024 08:29 PM
another thing to test is the Screwfix iOS app, it will never load with the three broadband but will load Ok with my usual mobile data. This is not fixed with only using band B1
on 11-04-2024 08:37 PM
By any chance are you using the APN 3internet for your Three broadband? Sometimes that would cause issues for myself so I switched to using three.co.uk instead and it helped with some random errors however, all Three APNs do currently suffer from the PR_END_OF_FILE_ERROR issue
Additionally, is your phone using 4G or 5G? It may potentially be linked to that
Unfortunately I would need to update my phone to use that app and I can not do that at this time
11-04-2024 04:07 PM - edited 11-04-2024 04:07 PM
Hi everyone,
Just to confirm, we're still looking into these issues, I'm awaiting some feedback on some internal testing following the info we gathered a couple of weeks back.
@andym00 and @Nameless thanks for the info about manual band selection, I've passed this on to my colleagues who are investigating, hopefully this helps the investigation.
It sounds like this settings change has helped in these cases regardless, is anyone else able to share if this impacts the frequency of errors when only connecting via bands B1 + N78?
on 11-04-2024 08:29 PM
Hello and thank you for your update
I continued to test Bands B1, B20 and B28 with Band N78 and the PR_END_OF_FILE_ERROR issue is still there however they are far less frequent (Effectively rare in my case) compared to using Band B3 with no single website being a common breaking point...
I then started to test without Band N78 for a limited time however that would severely limit broadband speeds to the 4G limits and that is not really an option when paying for a 5G service... Needless to say, I did not encounter the issue in that limited test however it was not as intensive compared to my usual tests
My guess would be that there is some handover issue between Band N78 and the 4G bands which is magnified most with Band B3 compared to the others
At some point I used to be connected to Bands B1, B3 and N78 twice according to the router (An NR5103EV2) although lately it has been Bands B1 and N78 twice instead - I am not sure why
(For completeness, Cloudflare's WARP is only affected by changes to the overall broadband speed such as disabling Band N78)
I will continue with Band B3 disabled for now and will continue testing
