EDIflyer
626 REPLIES 626
bytespider
For the sites I frequent, including Github, things have been fine. But I also use Chrome so I may not notice a slightly longer delay as the page loads.
Nameless
Established
A check-in with no changes
Using my list of problem sites and starting backwards, Pavlovia and Background Noises • Ambient Sounds • Relaxing Music | myNoise ® both gave the error the first time I loaded both websites
How long did it take to encounter the issue? Less than 10 seconds
Needless to say, this is still a problem
I remember that there was supposed to be regular check-ins with updates from Three - It seems that there must be another issue there...
torz77
Still the same crap. Is anyone actually bothering to try to fix this, or are three just hoping it will go away by doing absolutely nothing?
Hint: that isn't working, guys. Well over a year now. Madness.
EDIflyer
OP of the thread here! - still experiencing the same issues but FTTP now an option where I live so I'm leaving to move to that instead. Although the VPN workaround does the trick for my PC I find it a pain having to activate it on other devices and just want a nice stable connection that works!
cerihughes
Likewise. The FTTP installers are here as we speak. I'll be glad to get away from this unholy mess. The last straw came when I tried to install a Blink doorbell and it would barely work due to the number of errors connecting to their servers.
Nameless
Established
An extra for this week:
Disabling band N78 to enforce the 4G mode does not eliminate the issues - It just becomes rarer to encounter
I will continue testing things as usual
Nameless
Established
A check-in after a fairly busy week
I have not seen any changes - In fact before sending this message, I started going through the list of problem sites in reverse order and hit the issue with the second site (That would be Overview of Pi-hole - Pi-hole documentation)
Maybe things are worse now? I still use Cloudflare's WARP therefore I would imagine that VPN and WARP (Or equivalent) users have been shielded from this
Midnight54
Established
Well glad I left some time ago but still get the message notifications of updates, and keeping options open for when I'm next out of contract.  Disgraceful to see issue still not resolved nor seemingly narrowed down much.  I thought there was going to be promised regular updates and transparency on getting this issue expedited.  So far the only progress appears to have been red herrings of reports of people getting it a bit less on some days, which has always been the case.
I guess Three are just happy enough to let the issue lie as the majority of people will just blame their phone, pc or external website etc when the blip occurs, or using chromium browsers so see it less often
andym00
Can I ask who you went with, and what the 5G performance is like relative to Three ?
Midnight54
Established
I went with a fibre connection Grain, and get a solid gigabit connection with next to no issues since *touch wood* - price for the 18months was on average only a couple quid more a month than Three.  Remains to be seen what will happen at end of contract though when every penny counts
