EDIflyer
626 REPLIES 626
bytespider
Maybe when the merger with Vodafone is complete someone will take pity on us.
Nameless
Established
A check-in
I have not seen any changes so far
How are things for you all?
andym00
Still broken here, nothing changed at all.. Living with ~100Mbps over 4G is starting to grate really badly for work stuff..
EDIflyer
Zero change here, just as bad as ever - can get round it with a VPN on PC but still issues for other devices like TVs where I keep having to reload apps to get them to work.
torz77
Just checking in to say, no change here. Issue still persists.
Lets hope 2025 can be the year that Three finally solve the issue.
AlSeek
A question for those who have a Three SIM and also are using a mobile virtual network operator (MVNO) on Three's network...
Any MVNOs on Three's network not experiencing this issue?
Nameless
Established
As far as I have tested, all Three MVNOs have this issue - You can test each one by changing the APN details and that is what I do when I test things
Nameless
Established
Just a quick check-in
I moved the router and tested both Wi-Fi and Ethernet and the problem is still there although it took longer to see it as I have been connected to Band B1 lately despite all bands being enabled
Usually, if I am connected to Band B3, I encounter the PR_END_OF_FILE_ERROR at some point whilst going through the list of problematic sites once. Today I went through the list twice in immediate succession then started a round of speed tests for ~15 minutes due to the router's new position being closer to the nearest mast by ~3m-5m. After that, I encountered the problem when going through the list for a third time
The router's last uptime was ~51 days if I read it correctly before turning it off
How are things for all of you?
AlSeek
More or less the same as usual for me. As mentioned long ago in this thread, I am running my router as 4G only and get the connection issue infrequently. In 5G mode I get the error frequently. So that may be band related or maybe not, I don't know.
I have tried going on 5G and disabling band B3 which made no difference to me since I still got the error quickly.
Indeed connected by 4G right now I'm apparently on bands B3,B32,B1 and the issue is currently infrequent.
Nameless
Established
The error is definitely somewhere in Three's infrastructure although I have not tested any of the 4G bands alone as extensively as I have tested them in combination with the N78 5G band
Have you tried the 4G bands individually? It would probably have the biggest impact on your speeds compared to using a VPN or Cloudflare's WARP although these are currently the only known methods of avoiding the highly variable PR_END_OF_FILE_ERROR completely
I will try testing the 4G bands individually when I get time
