on
29-10-2022
10:05 AM
- last edited on
25-11-2022
02:55 PM
by
on 11-11-2022 03:10 PM
Hi @Dazzar,
Thanks for this insight, knowing the issue is partly DNS related ought to narrow things down for the investigating team.
on 10-11-2022 08:44 PM
Hi I have a mesh system, it is not via bridge , but I changed the mesh system to connect via a dns of 1.1.1.1 and Ethernet to the ZTE801a and it works , I have not tried via bridge mode as I do not want to stop it running
on 09-11-2022 10:02 AM
This issue doesn't seem to be limited to Sky Glass. I'm also unable to access any of the on demand services on SkyQ while using Three 4g home Broadband. i can only assume the issue is related!
on 10-11-2022 07:38 AM
The issue is with SKY as a whole for some reason sky and 3 have stopped talking to each other . It’s either a filter 3 has applied or an update sky have applied, so far leaning towards 3 since they forced an adult filter on people and other updates
on 08-11-2022 11:39 AM
Hi everyone,
I'm sorry to hear that you've been experiencing these issues with using Sky Glass with your Three Broadband services the last few weeks. I've found these 2 similar threads on the community so they've been merged. This way we can keep any updates on this issue clear.
I'm making enquiries along with Pete as to what's causing these issues, thanks so much for the info you've supplied so far, I'm sure this will help narrow down what's causing this.
I'll let you know as soon as I can share anything more. Thanks for your patience.
on 09-11-2022 06:06 AM
Hi, can you also if three will release you from their contract over this so I can go elsewhere and actually get a service , ie all the others that work as in everyone else ………
on 09-11-2022 09:49 PM
That's a good question, if not will we get a partial refund of our monthly payments while this problem continues?🤔
on 10-11-2022 08:45 PM
Try a dns of 1.1.1.1 mine is via a mesh but is now working
on 12-11-2022 09:56 AM
@Dazzar how do you change it? I'm using the netgear orbi mesh system, do I change it on the three router( ZTE MC801A) Or my orbi router?
on 02-11-2022 10:16 PM
Up to 2 weeks ago I was using sky glass tv with their Pucks , something has changed as I cannot use my playlist anymore, sky blame 3 as they have applied a filter , anyone know what they are talking about and how do we get three to deal with it ?
