Sky glass and Sky Q issues - three 5g home broadband
p1d9m73
Hi, I was just wondering if anyone else was running a sky glass tv off their three 5g home broadband? I'm having a lot of problems viewing on demand programs but it's very random. I can stream something on more 4 but not on my5 and certain movies on the sky cinema channel won't load either. I've been told by sky that it's a security thing, I didn't quite understand it but basically when I try watch something on demand the glass tv sends a request to the ip provider and sky are saying the tv must be getting the wrong answer so the program won't load🤷‍♂️ just wondered if anyone else is experiencing the same? It's only the last 2 months it's started happening, the 1st time it happened it lasted about a week and it's been about a week this time too. All live programs work fine.
146 REPLIES 146
Dazzar
Established
Right spent ages on the phone yesterday with sky, they are blaming three, they claim that they have not changed anything , even though I was not having any problems prior to them putting this puck live stream thing online and doing the update for it. They blamed the internal workings of the router, I have though tried a huawei Cpe pro2 and the LTE 801a , I had nothing else connected to the lte , restarted the puck to factory settings, turned the wifi off on its settings, so nothing else but the single puck was connected to it, and it still did not work, but sky insist it is 3 causing it. I have though connected to my old 2mbps BT wifi 2 hub through its copper wires and I do not have the issue, this would back up Skys comments though, please if there is a mod on here can they get sky and 3 engineers talking to each other
p1d9m73
I've spoken to three and they said they don't have the ability to block anything, which I find strange, he 1st blamed it on my adult filter being turned on so he turned it off, still didn't work. Asked me the usual, restart router, restart tv, still the same. Its obviously a three issue as if you use any other ip provider it works fine. I think trying to get sky and three to speak to each other is gonna be very hard though, they just want to blame each other
Dazzar
Established
This morning I used my Vodafone iPhone and the personal hotspot, connected the playlist and it worked fine, kept the program running and reconnected three and it worked fine, then I stopped the program and restarted through 3 and it refused to run, thus making it a 3 issue
p1d9m73
That's different to mine, if I use my sky data on my phone and hot spot the tv to it, it works fine but soon as I switch back to three it stops within seconds. Its really frustrating but I'm glad I'm not on my own with the problem, the more people getting and reporting the issue the more chance they will sort it, hopefully.
p1d9m73
It's good to know I'm not the only one having the issue but bad that it's happening. Been on the phone to sky and they said the same about ip address,  it seems more than 1 ip address is pinging back to sky that's why content doesn't load. Please can you sort this out three, I'm tied into a 24 month contract and right now I'm very frustrated with the service.
Dedisense
I am having the same problem.
Dazzar
Established
Hi I have the same problem , it’s a playlist issue , for example I watch FBI all previous series will run but the latest one will not, it is a problem with three as I switched to BT that I have as back up but incredibly slow and it works fine, it’s something to do with how 3 allocate their ip addresses
Hi, p1d9m73.
Gosh, that sounds annoying! I'm not sure why the TV would do that, and the explanation they have given isn't too clear on what might be causing it.
Are you able to ask The Sky Glass team if there's any specific requirements that are needed in order to get those channels and services working? If we can get that info, we might be able to figure what's going on.
Dazzar
Established
Pete one thing I have found out is that a lot of people are complaining about an adult content filter being applied in October and having to connect a credit card to prove they are over 18 , I wonder if this has somehow affected the home routers ? I cannot find it on my router but it does not mean it is not there ???.
Nathen2022
Tried this and didn't make any difference,  I've seen allot people having the same issues and they are all on three 5g hub!!!!!! Come on Three there is an issue with your hubsort it out....
