on 23-02-2024 12:43 PM
Does anyone else use the USB socket? I've got a large USB stick in there so I use it as a cheap NAS. It worked on my old router and it worked on this Zyxel router for a while but now it has a problem. I can read files from it and I can copy small files to it but larger files will cause an error from my Windows PC. (No it's not full)
My workaround is to take it out of the router, plug it into the PC, and then copy the file. Bit of a pain!
Thanks.
on 24-02-2024 01:13 PM
Hi Peter, it's Peter here. I noticed when copying on my PC that the USB stick will suddenly drop in speed. Apparently they do this when they need to search for space. It only happens after copying about 500GB in one go. I guess the router can't cope with that delay and throws an error. Tested my theory with a USB HDD plugged in the router and that works OK so switching to that.
on 25-02-2024 05:37 AM
I mean 500MB!
