03-08-2023 10:41 PM - edited 03-08-2023 10:56 PM
Hi All,
I just got the
Zyxel NR5103E 5G Hub & currently on V1.00 (ACBJ.0) b12.
Internet works.
Ring doorbell Does not. My camera's cant connect. Connects to Wifi but then says it fails because there is no internet connect but the hub is indeed connected to the internet.
Netflix comes up with a NW-2-5 error comes up.
Looked online and seems to be that there is a new firmware, but I have no idea how I download it? I restarted my hub and hoped for the best but nothing. Any ideas where I can download it and upload it directly.
Also any recommendations on the ring challenge I'm having?
on 04-08-2023 02:09 PM
Hi @Yasarahmad, @andyvee,
The firmware update should be getting pushed automatically from us. Have you been in touch with the Broadband Teams about this?
For the device connectivity issue, there's been a few similar situations coming up recently. Although it was initially about VPN connection issues, FYI : IPv6 Prevented VPN Connection gives info about setting the APN to manual mode and IPv4 only which may help with the Ring issue.
on 04-08-2023 04:40 PM
Sorry - should have been clearer - I have no issues other than the firmware doesn't appear to be updating from b12. I'm in no rush - I'll wait as it is likely to break my IP passthrough with the IPv6 so quite happy for it not to happen TBH 🙂 just odd that it hasn't updated.
on 03-08-2023 10:49 PM
Open the settings in a Web browser and there should be an option to check/update firmware. The settings usually open if you type the ip address into the browser, or Google how to open the settings.
on 03-08-2023 11:00 PM
No option to do that.
on 04-08-2023 09:53 AM
I'm in the same position - router on b12, no option for auto update, and it doesn't seem to be updating by itself either
on 04-08-2023 05:24 AM
