on 15-02-2023 03:08 PM
Hi everyone I have a solid 5g connection to my phone but my zte router keeps dropping the 5g I know there is work in my area but why would it only effect my router many thanks.
on 18-02-2023 11:20 PM
Unfortunately this sounds like you have the same B12 firmware bug a lot of us have with this router
The B12 update was pushed around October time and causes the exact symptoms you describe
Three do not appear to believe/acknowledge that this issue exists. I have tried multiple times to get acknowledgment of this problem via this forum, but have had no success.
on 26-03-2023 01:57 PM
Seems this is a common issue with ZTE MC801A routers (see the many posts)
I have had mine since middle of Feb 2023 and it continually drops the 5G connection without recovering.
I have switched mine to 4G only and suffer the loss of speed but I am not happy.
Firmware version 0B15 (Latest)
on 19-02-2023 12:53 AM
My be looking into closing all 5 accounts with three maybe they will listen very much dout that will happen paying for a service that is second rate at best thank you for your reply gagandeep.
