Sercomm LTE2122GR Password
djt100
Hi All,
Anyone had issues with the passwords on this router.
I've received today and managed to connect by scanning the QR code on the rear, and I've loaded the three app, within the 3 app the wifi password is different to that shown on the rear of the unit.
trying to get to the admin console for the router, on the rear of the router it says the password is admin , but trying to access (via 192.168.1.254) its telling me incorrect username or password using admin for both.
Could do with knowing accessing if for no other reason than changing the stupidly complex and long default password.
4 REPLIES 4
crypt0ninja
Established
Hi @djt100,
The router login details should work especially if its a new router, very strange.
There's probably a small pin reset button somewhere on the router, might be worth factory resetting it using that reset button which should set the username and password to whatever is stated on the router label.
Cheers
djt100
Already tried that still no joy.
Erikasgdz
I've got the same issue here pal. Put my sim card into a different hub and working no problem. Its a router problem.
crypt0ninja
Established
Hopefully someone else who has this router can chime in!
